New firmware android 9.0 for Amlogic S905x
    Originally posted by mAtvXk View Post
    Don't be fooled, this is false advertising, the box has Allwinner H6 cpu (Mali-T720 gpu) !
    thank you, i guess amlogic s905x
      Originally posted by sagert View Post
      Install root.And using root using the file manager, install your wifi driver files in that folder.Or you need an external wifi adapter.
      Can you guide me on rooting? Thank you !
        1.Download the Magisk 19.3 files.
        2.Go to the Update&Backup program and select the file downloaded in .zip format .
        3.Sew it through this program.
        4.After returning to the system ,download and install the Magisk Manager program.
        5.Go to the Magisk Manager program and agree to the changes.
          Thank you so much, but I still haven't rooted your way!
            What did you do in detail?Maybe the topic about Magisk on xda will help you.
              Hi !
              I just did it! Rom doesn't suit my wifi, After rooting, I copied the wifi driver to: VENDDOR-ETC-WIFI, but it still didn't get it! Can you help me?
                [QUOTE = toilatoiok; n794056]
                Perhaps you need to put them in /vendor/lib/modules.
                  Thank you !
                  But I still haven't made the box receive wifi
                    Thank you !
                    This is the core, only a few make it.
                      I see you say edit and replace file system.PARTION right? How did you do it? Can I follow this way to modify the wifi driver?
                        Install the terminal emulation program.Open it and write. 1. su
                        2. lsmod
                        And you will find out which modules work for you now.This is the core module support.
                          2. lsmod
                          Thank you !
                          I will do as you
                            2. lsmod
                            Mine like this, what should I do?Click image for larger version
                              Mine like this, what should I do?Click image for larger version  Name:	a210231982af7bf122be.jpg Views:	6 Size:	93.8 KB ID:	794156
                              You can replace boot.PARTITION wth frmware VIM1_Pie_V190823 using the Amlogic tool v6.0 .The firmware is here.This is true at your own risk and risk.
                                https://docs.khadas.com/vim1/FirmwareAndroid.html
                                Thank you !
                                I will try it as you guide
