Failed a 7% with DiskInitial error.
New firmware android 9.0 for Amlogic S905x
Originally posted by sagert View Posthttps://www.google.com/search?client...utf-8&oe=utf-8
Maybe here you will find the answer to your mistake.
For what it's worth he also tried flashing my rom, he sent me a firmware that was working on his device (7.1.2 standard android), for me to replace the launcher ect but any changes to that firmware (even just removing one app) would cause it to fail to burn on my 1gb box at 97% (where unmodified flashed and worked fine)
I remember somting about maybe it could be to do with some sort of secure boot (probably wrong term) or something of that nature, also could it be to do with a custom uboot? (Maybe not because it also flashed on my device too), I kinda want to figure this out, its going g to annoy me otherwise hahaha
Originally posted by aidanmacgregor View PostFor what it's worth he also tried flashing my rom, he sent me a firmware that was working on his device (7.1.2 standard android), for me to replace the launcher ect but any changes to that firmware (even just removing one app) would cause it to fail to burn on my 1gb box at 97% (where unmodified flashed and worked fine)
Originally posted by neilop View Post
Tried this, although post links I could find on the site indicated it was for the 2GB box. Downloaded aml_upgrade_package_s905x-tx5-atv9-v6-fix-ce from https://daivietpda.com/2020/03/rom-a...mited-tx5-pro/
Originally posted by sagert View PostIt is possible to root using Magisc 19.3.You need to update this file through Update&Backup.Then install Magisc Manager.
Do i need custom bootloader to do root, right? I'm trying trying to root Youit OTT Tx5Pro box with Magisk and had no success...
This box appears to not boot from card...
Thank you by your work and time sagert! :-D
Originally posted by oDuda View Post
Using DaivietPDA rom, some times with little issues in ethernet, i need to turn on/off wi-fi and it backs to work.
The instruction is separate ,complicated.Last edited by sagert; 10 July 2020, 12:07.
There are currently 1743 users online. 3 members and 1740 guests.
