New firmware android 9.0 for Amlogic S905x
Originally posted by sunsoft30 View Post
Originally posted by sunsoft30 View PostHi Sagert plz remove the unfinalised rom from the forum to avoid future problems to other users. Else I may report this to forum administrator to safeguard the interests of other users.
Thank you aidanmacgregor for your only rescue as nand pin short. I had tried many ways of installing magisk, twrp manager but all in vain. Had the rom had built with recovery, which is a mandatory requirement, there would not be much problems to users. At last I found out the nand pins and flashed aidans 7.1.2 version successfully. Get out of that half baked rom. I understand one cannot make a perfect software at one stretch. But it should meet minimum requirement. That is my point. Sorry sagert for disturbing you a lot. Now I am happy with aidans 7.1.2 version. Thank you guys for the help offered.
Originally posted by sunsoft30 View PostThank you aidanmacgregor for your only rescue as nand pin short. I had tried many ways of installing magisk, twrp manager but all in vain. Had the rom had built with recovery, which is a mandatory requirement, there would not be much problems to users. At last I found out the nand pins and flashed aidans 7.1.2 version successfully. Get out of that half baked rom. I understand one cannot make a perfect software at one stretch. But it should meet minimum requirement. That is my point. Sorry sagert for disturbing you a lot. Now I am happy with aidans 7.1.2 version. Thank you guys for the help offered.
Sagert has been a great help and I and others senior and junior members have enjoyed testing, Sagert thanks for all your help.
aidanmacgregor, installed the daivietpda rom, aml_upgrade_package_s905x-tx5-atv9-v6-fix-ce, on my Abox 1G/8G, eveverything worked great once i rooted it, except my original remote.Funny thing is prior to this rom I have installed your [V 7.1] Nexbox A95X Remote WITH POWER ON BUX FIX (07/07/2020), it also worked well including the A95X remote, but wanted to test ATV9. I even downloaded your nextboxremotezip patch and tried to install it on davietpda without any luck, any idea how to modify that rom to include your patch? thanks
Originally posted by minonano View Postaidanmacgregor, installed the daivietpda rom, aml_upgrade_package_s905x-tx5-atv9-v6-fix-ce, on my Abox 1G/8G, eveverything worked great once i rooted it, except my original remote.Funny thing is prior to this rom I have installed your [V 7.1] Nexbox A95X Remote WITH POWER ON BUX FIX (07/07/2020), it also worked well including the A95X remote, but wanted to test ATV9. I even downloaded your nextboxremotezip patch and tried to install it on davietpda without any luck, any idea how to modify that rom to include your patch? thanks
Originally posted by aidanmacgregor View Post
hi, as far as i am aware the remote information has moved to the vendor partition and is no longer in system partition, i also think that the files are now called remote.tab and i assume they will have a diffrent format, its still very early days for me with 9.0 firmwares with regards to diffrences vs 7.0 firmwares still learning alot, if anyone else has any more info/knows better please let us know
or @sagert
Thanks aidanmacgregorLast edited by minonano; 29 August 2020, 04:19.
Hi minonano I don't want to argue with you gentleman. I need not be a senior member to care for other members. Every member should care for other members. It would be better to maintain the decorum in a public forum. A junior member is not inferior to others in any way. So try to respect other human beings, which is a basic lesson in life. Android, custom Roms are secondary. I respect every member. Thank you.
There are currently 3006 users online. 1 members and 3005 guests.
