sunsoft30 piece be with you my friend, all good now.
New firmware android 9.0 for Amlogic S905x
Originally posted by minonano View Post
sagert thanks for the info, but I would rather take them from the firmware where the remote works, and that is aidanmacgregor's, but unfortunately it's Android 7 which is completely incompatible with the ATV9. Unless anyone else is aware of an ATV9 firmware compatible with the Nexbox A95x remote, and that will be a great help, thanks.
On 4pda there is a firmware theme for Nexbox A95x.There is an android 9 ATV firmware from alex_161_rus.Probably for boxing with 1gb memory.
https://4pda.ru/forum/index.php?show...#entry96944200
sagert I found it, thanksLast edited by minonano; 29 August 2020, 18:45.
sagert, downloaded the alex161rus, v1.1, everything works, remote, wifi too, but wanted to experiment with your suggestions, so i copied the remote.cfg, and all remote.tab(s) and the keylayout, and pasted them into the other daiviet rom, but no luck. S0 i decided to go back to alex rom. Thanks for your help.
Originally posted by minonano View Postsagert, downloaded the alex161rus, v1.1, everything works, remote, wifi too, but wanted to experiment with your suggestions, so i copied the remote.cfg, and all remote.tab(s) and the keylayout, and pasted them into the other daiviet rom, but no luck. S0 i decided to go back to alex rom. Thanks for your help.
Originally posted by JM007 View PostI HAVE X96 SMART ANDROID 6.0 TV BOX KODI 16.1 S905X 2GB / 16GB US PLUG
I WANT TO INSTALL ATV 9 OR ANDROID 9 ON MY DEVICE
PLEASE PROVIDE ME STABLE UPDATE WITH ALL FUNCTION WORKING
SAFEST MEDHOD PLS
PLEASE HELP ME OUT
it has bluetooth and wifi
provide me steps to install
Guest
Originally posted by JM007 View Post...TEACH ME HOW TO INSTALL....
There are currently 2006 users online. 0 members and 2006 guests.
