New firmware android 9.0 for Amlogic S905x
Originally posted by stelios10 View Post
I UPDATE MY X96 android box to this firmware you made but unfortunally i dint like a lot cause doesent work properly so i tried restoring back to its oldest firmware but cannot root ,do you have any ideas why please help
Hello, I have a 2016/17 Q box amlogic s905x with android marshmallow 6.01 version qb0005. I believe the firmware became corrupt so I looked everywhere for the stock firmware but couldn't find it. The only firmware I found that worked was marshmallow 6.01 version qb0003 which is really old and play store would not update either. Does anyone have the stock firmware or maybe an updated version like android 7.1 for this box please?
Originally posted by MULDER View PostWorks fine, but.
is there any version android 9 other than atv? or how can i install regular google store app?
Originally posted by indiekid!!! View PostHello, I have a 2016/17 Q box amlogic s905x with android marshmallow 6.01 version qb0005. I believe the firmware became corrupt so I looked everywhere for the stock firmware but couldn't find it. The only firmware I found that worked was marshmallow 6.01 version qb0003 which is really old and play store would not update either. Does anyone have the stock firmware or maybe an updated version like android 7.1 for this box please?
Originally posted by sagert View PostHERE just made android 9 ATV. It loads and works fine. Only with the keyboard you need to install another.
https://mega.nz/#!G8020SIY!N0sB8XbiR...s-1IObWpzibYNo
Can replace the power supply.
i have also sorted out the remote control but i can't get scan codes for some buttons when i press the buttons on key_test app. i also tried dmesg via terminal but it didn't work for any button.
file below is for X96 S905x remote.
buttons not working
left, right and 4 (unable to obtain scan code)
setup (tried to assign it to settings but didn't work), APP, KODI and mouse button (not assigned to anything).
Originally posted by addy_86 View Post
Thanks it worked. i added some more power to the box via USB on the side and it worked. what power should i be looking at? previously i had 5v 1A plug and now i got 2 plug at 5v 1A. it seems more stable and no more random reboots.
buttons not working
I have 5v 2A.Works fine.You can also repair it.If you can open it and replace the parts.In the firmware from daivietpda v6 ,I have many buttons on the remote control.
There are currently 3268 users online. 0 members and 3268 guests.
