New firmware android 9.0 for Amlogic S905x
Originally posted by sagert View Post
You can open the vendor file from the Daivietpda firmware.And get the remote.tab files from there and transfer it to this firmware using root.
OOps, good news: i have 2 different remotes. One is working fine, all key works flawlessly. i'll post image of these 2 remotes
Originally posted by ducdt0407 View Post
Already did that, but ir remote still not working. I've also edited manually remote.tab2 and vendor0001 (my model is x96 with s905x 1G/8G) comparing with the stock remote.conf file from stock FW of x96 (mine is fe01), but nothing works. Maybe need to research something else.
Maybe dtb should be transferred from Daivietpda firmware.But the firmware format is different .I still don't know how to replace dtb.
BTW this is the remote that works without problem (except Mouse button). It’s the stock remote came with my tanix tx3 mini (s905w 2/16).
Originally posted by JG420 View PostSo I've just installed this to my x96 with rtl8189 wifi. WiFi works great. Rom booted and works great. One major issue! I can't install any apps! It won't let me install from SD or USB storage!
can this ROM be used for Android TV Boxes with the following specifications: - Amlogic S905X processor, - quad core ARM Cortex-A53 @ up to 1.5 GHz with penta-core Mali-450MP GPU @ 750 MHz - 2GB RAM - 8GB ROM Video Output - HDMI 2.0a up to 4K @ 60 Hz with HDCP 2.2, CEC, HDR10 and HLG HDR, Video Codecs - VP9 Profile-2 & H.265 MP-10 up to 4K @ 60 fps, H.264 AVC up to 4K @ 30 fps, H.264 MVC up to 1080p60 Connectivity: LAN: 10 / 100M Ethernet Wifi: 802.11 b / g / n / ac
and this room does support double joystick?
waiting for the answer. thank you
Originally posted by zalpoke View Postcan this ROM be used for Android TV Boxes with the following specifications: - Amlogic S905X processor, - quad core ARM Cortex-A53 @ up to 1.5 GHz with penta-core Mali-450MP GPU @ 750 MHz - 2GB RAM - 8GB ROM Video Output - HDMI 2.0a up to 4K @ 60 Hz with HDCP 2.2, CEC, HDR10 and HLG HDR, Video Codecs - VP9 Profile-2 & H.265 MP-10 up to 4K @ 60 fps, H.264 AVC up to 4K @ 30 fps, H.264 MVC up to 1080p60 Connectivity: LAN: 10 / 100M Ethernet Wifi: 802.11 b / g / n / ac
There are currently 2925 users online. 0 members and 2925 guests.
