New firmware android 9.0 for Amlogic S905x
You can just do level one unpack repack with version 6 of tool, the tx5 system works in this firmware gboard has no letters on start up so you need remote with keyboard to setup the n5 firmware works on this bootloader and the tx5 system works with this firmware as well. Tx5 ATV with wifiLast edited by mick154; 09 November 2019, 21:37.
Originally posted by sagert View Post
X96 2gb 16gb wifi 8189
My S905X Boxes have WIFI AP6255 chip.... anyone know how to install the drivers properly? I would like to upgrade my boxes to a new stable firmware as there are issues with the Stock firmwares on both boxes. Can’t watch anything on the web browser in full screen as most of the screen goes green on full screen.
I prefer Android ROMs not based on Android TV as Android TV requires many of the apps I use to be side loaded and I have become used to using my mouse to control the TV box.Last edited by DrDroid; 10 November 2019, 14:13.
Originally posted by soldiaz View PostDid not work for my... :-(
Tried to copy over xxx.img files to the flashable zip, but did not work..Ill try some other archivers
Originally posted by sagert View PostNew firmware android 9.0 for Amlogic S905x.
Firmware address : https://mega.nz/#!b0cCSIYS!-9ML4Kocx...V_nIs7-UQ0KfeI
I write English with translation. Therefore, I will be laconic. Write your feedback. I made this firmware as a port.
Â
WiFi and Ethernet working.
Â
Remote not working so will try to see if my Remote config file will work however I doubt it will work properly as it is linked to the SystemUI although both remote looks similar I have no idea how each button on my remote will work with this firmware. Will update once I have fully tested everything and see if I can tweak it to my liking.
Originally posted by DrDroid View Post
Testing your ROM on my Mini M8S II.
key_test.apk
You can also install the file along the path /vendor/usr/keylayout/ .It must be unpacked before installation.
Vendor_0001_Product_0001.zip
The remotes are different.There is a program for determining button presses.
key_test.apk
I also installed your ATV 9 ROM on my x96 box (S905x 2/16) successfully and faced the same remote not working issue. Actually this is the only ROM that has worked with wifi where as all the ROMs I tried (ATV, Poison, Minixfreak etc...) where giving wifi connection issues.
The ROM is stable and runs smooth with everything working except the remote. I tried installing the APK you provided and the only keys that work are HOME, DOWN, UP & BACK and nothing else. I'm not able to copy the keylayout file into the Vendor folder as I suppose the ROM isn't rooted? Could you please help me with getting the remote working as this will be the best ROM for me to use on daily basis!
Thanks once again!
Originally posted by markshane View Post
Hi sagert,
Thanks once again!
Hi sagert,
Thanks once again!
key_test.apk
There are currently 2333 users online. 0 members and 2333 guests.
