I did the following steps: Root, then copy the wifi driver file into: vendor-ect-wifi ... then install full permison for the wifi folder! Reboot the device is ok, Box received wifi!
New firmware android 9.0 for Amlogic S905x
Originally posted by toilatoiok View PostI did the following steps: Root, then copy the wifi driver file into: vendor-ect-wifi ... then install full permison for the wifi folder! Reboot the device is ok, Box received wifi!
??????Congratulations. Then you don’t have to do anything else.
Yes !
But I still want to edit my own Android 9 rom, currently can't find any software that can do this? Do you know any software?
Originally posted by sagert View Post
I used this software, but when I repackaged it, I failed to boot
I found twrp 3.3.1 for amlogic devices on 4pda from user VVitaly.It should start through the Update&Backup program.But i have not tested it yet.Message 2593.
https://4pda.ru/forum/index.php?show...#entry92355662
P.S I tried with this twrp through the Update@Backup program,but I was unable to start twrp.Last edited by sagert; 07 January 2020, 18:29.
Hi Guys, I have a Nexbox A95x - B7N 2GB-RAM 8GB-ROM and I have the firmaware of daivietpda (aml_upgrade_package-tx5-atv9-ap6212-1GB-2GB.7z) installed. I want to root the device because I want to fix the problem with the wifi. How can I root the firmware? How can I install TWRP and what version do I need. I tried the TWRP 3.2.2 temp to get access, and installed recovery.img (TWRP) from there. But it doesn't work. So far I understood that I first have to install TWRP and then Magisk.zip to get the root rights.
Originally posted by Genius85 View PostHi Guys, I have a Nexbox A95x - B7N 2GB-RAM 8GB-ROM and I have the firmaware of daivietpda (aml_upgrade_package-tx5-atv9-ap6212-1GB-2GB.7z) installed. I want to root the device because I want to fix the problem with the wifi. How can I root the firmware? How can I install TWRP and what version do I need. I tried the TWRP 3.2.2 temp to get access, and installed recovery.img (TWRP) from there. But it doesn't work. So far I understood that I first have to install TWRP and then Magisk.zip to get the root rights.
On 4pda there is advice but it is in Russian. But I have not tested this method yet.
I also wrote on the last page how to make a root. That I already used.There is no twrp yet.
Hi Sagert thanks for your help,
I use the original version of DaivietPDA.When I flash magisk via the update menu, he prepares the installation,
restarts the box and I receives the error message:
E:Signature verification failed
E:error 21.
I also tested the version X96_Khadas_Vim_Pie_ATV from this thread, root works when i installing Magisk.
But I would like to use the version of daivietpda with WiFi and I must root this rom.
I also tried to patch the boot.img with magisk and then to replace and flash it, But that didn't work.
What possibilities do i have to root this Rom
There are currently 2005 users online. 1 members and 2004 guests.
