New firmware android 9.0 for Amlogic S905x
Originally posted by blyx21 View PostThus this works with mini m8s ii? S905x chip. Thus wifi, Bluetooth works?
My new favorite ROM. Remote does not work correctly (some buttons work). I tried to root with Magisk, its installed and seems to be working but I can't write to the vendor/etc folder to edit remote.tab2. Keep getting "Permission Denied" with ADB and Total Commander. But it does work well with HDMI CEC on Samsung TV. Thanks for the hard work!
Originally posted by firmtech View PostMy new favorite ROM. Remote does not work correctly (some buttons work). I tried to root with Magisk, its installed and seems to be working but I can't write to the vendor/etc folder to edit remote.tab2. Keep getting "Permission Denied" with ADB and Total Commander. But it does work well with HDMI CEC on Samsung TV. Thanks for the hard work!
You can put temporary twrp on it and SuperSU can be installed in it.
Ok, root is working now, not sure why it wasn't before. I looked at my stock rom and found the remote.conf file. it is a 0xfe01 remote. Not sure why only a few remote buttons work, others are not mapped correctly. Here is the first few lines of my stock rom remote.conf file.
#amlogic NEC remote
factory_code = 0xfe010001
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 1
Originally posted by firmtech View PostOk, root is working now, not sure why it wasn't before. I looked at my stock rom and found the remote.conf file. it is a 0xfe01 remote. Not sure why only a few remote buttons work, others are not mapped correctly. Here is the first few lines of my stock rom remote.conf file.
#amlogic NEC remote
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 1
There are currently 2251 users online. 3 members and 2248 guests.
