New firmware android 9.0 for Amlogic S905x
Originally posted by sagert View Post
Originally posted by DiogoSilva48 View Post
ATVXPERIENCE doesn't have the drivers for QCA9377 yet but they said they're going to add them, so I just have to wait for the build I guess, no need to have extra work for nothing and I'm also kinda short on time right now because of college. But I need to do some investigation on the noise reduction situation, see what's missing to change that.
Originally posted by timosat View PostHi Sagert, do you have Mibox S port where WiFi 8189ftv works?
The Mibox S custom port by Aidan MacGregor only have WiFi AP6212, and QCA9377. Please if you have the Mibox S ported rom with wifi8189f drivers share the link. I really need it because of Google certification.Thanks.
Originally posted by aidanmacgregor View Post
hi, have you tried other 9.0 roms for s905x? To see of wifi works in any of them, then can look at removing relevant files from /vendor for the Wi-Fi, if wifi wont work on any android 8+ S905x (android 8 for amlogic updated kernel in 8+ makes older drivers non compatible) then you may be out of luck currently, I would reccomend ethernet anyway I use powerline ethernet adapters as more stable than wifi
I only have one X96 2gb/16gb TV box.He survived several dozen firmwares.Now you have to often close contacts in order to flash another firmware.I had WiFi 8189 working on Aidan firmware but play market did not work.Perhaps this is due to different countries of residence that the play market did not work for me.You can still install atvexperience.Here they recently posted them in this thread.There are 6 of them..I was advised one and it worked WiFi 8189 and play market.For WiFi to work you may need to transfer files from system/lib where WiFi worked to this firmware in system/lib.Perhaps even in dtb the addresses of the drivers need to be changed which are responsible for WiFi.
Yes I have tried many android TV 9 roms and my WiFi worked. I also tried Android TV 9 by Daivietpda WiFi didn't work so I copied my WiFi drivers from Atvxperience 9.0 realtek/SSV to vendor/lib/modules and rebooted and my WiFi works.This was possible because of root on both roms. But Aidan Mibox S port is not rooted so I can't copy my WiFi drivers to it.
Ps wich davite t version did you modify, the old v1 to v4? Ot the newer V6 & v6.1 and was it the TX5 or TX5PRO?
Originally posted by timosat View PostCan you share me the link if Aidan rom that to your WiFi worked?. I have atvxperience 9.0 realtek/SSV and my WiFi worked there But I can't use those rom because they didn't pass safety net. That's is why I need Aidan Mibox S port. Please Sagert tell me how I can root Daivietpda android 9 rom with Magisk. With Magisk installed I can make it Google certified. Thanks.
simg2img /sdcard/system.img /sdcard/system.raw.img.
Then you need to mount 2 files one of which you want to copy the necessary files and the other into which you want to paste the necessary files.Mount one the system and the other to vendor.For example:
mount -o rw /sdcard/vendor1.raw.img /system
mount -o rw /sdcard/vendor2.raw.img. /vendor
Then copy the files from one to the other while preserving the rights.For example:
cp -r -p
[QUOTE=aidanmacgregor;n817098]
Ok I'll try taking the modules out of RTL SSV atvx, I'm working on v3, chromecast removed, and more de bloating, updated to the new gboard and more, modifying the system is working well for me but if I modify vendor my wifi stops working even if I make no changes but bluetooth still works, I can try the copy over though and see if it works
Ps wich davite t version did you modify, the old v1 to v4? Ot the newer V6 & v6.1 and was it the TX5 or TX5PRO?[/QUOTE
Ok it this: aml_upgrade_package_s905x-tx5-atv9-fix-ce. My WiFi didn't work on this I now copy my WiFi drivers (after comparing I saw only the difference was 8189fs.ko file and it was just only this file 8189fs.ko that copy and send to vendor/lib/modules) and rebooted.My WiFi started working.
In this thread I already wrote how to make root rights for daivietpda firmware.You need to read it because I forgot the details.Or you can use A logic tool v7.1 to disassemble the firmware.After disassembling the firmware pull out system.PARTITION or vendor.PARTITION and rename them to system.img and vendor.img.Then place them in the internal memory along the /sdcard path.On the firmware where the temporary twrp is installed.Then go to that temporary twrp.Then in it convert system.img to system.raw.img
cp -r -p
There are currently 1233 users online. 0 members and 1233 guests.
