[ROM] Beelink GS-King X & GT-King Pro ALVATECH Standard Android (9.0 Pie)
Originally posted by ngankvn View Post
I have never flashed a box through a USB-C Port before so I couldn't answer that question. I would say it should work, but I can't be for sure.
Thank you,
Alvatech
Is not !! Do not use type c to type A cables
The connection will fail while flashing ROM, as a result, you will not be able to boot the box
I had to buy a male to male usb cable to try again
Like I had mentioned in a previous post I wasn't sure. But it looks like user changwp has used it successfully for his/her box.
Thank you,
Alvatech
Originally posted by ngankvn View PostAre you planning to update the new rom? Beelink has released a new firmware that supports additional system switches (press and hold the power button on the remote control, system switching options will appear)
From what I gathered it's only for one type of box with a specific serial number and it's for people who want CoreElec and Android OS (Dual Boot). I haven't had time to look into it since I've been working on some other things at the moment. I will have a look later and see what it's about. Also I'm waiting for another box to come in.
Thank you,
Alvatech
There are currently 2929 users online. 0 members and 2929 guests.
