[ROM] Beelink GS-King X & GT-King Pro ALVATECH Standard Android (9.0 Pie)
Originally posted by zhangpaisen View Post
Hello, I have a new GTKING Pro, it uses the CPU of S922X-H, the serial number starts with 6B9H, which firmware can I use?Thank you very much!...
Thank you,
Alvatech
hi alvatech
thank you so much for the astonishing work.
kindly , how to fully uninstall chrome and install an older version? because when i uninstalled chrome (which comes as a system app in this rom) i ended up with a boot loop and i had to flash the box with a firmware all over again. but this time i used the default firmware because i can easily uninstall and install any chrome version...
i hope you can help out because i really like your rom but due to such issue , i reverted back to the original firmware.
thank you brother
thank you brother
Thank you!?
You'll need to delete the Chrome app outright from the system folder. I had responded to something similar here down below.
Thank you,
Alvatech
2 Links to install your own version of chrome:
This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from Beelink's stock ROM. This ROM was converted into Android TV. If you're looking for a Standard Android ROM look here (https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s922x/others-s922x/firmware-roms-tools-dq/787817
https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s922x/others-s922x/firmware-roms-tools-dq/778508-rom-beelink-gt-king-alvatech-standard-android-9-0-pie-s922x?p=792083#post792083
Originally posted by gridlock View Postalvatech... sorry to bother you again...
shall i delete the whole chrome folder and it's contents? (lib , oat , base.apk , split_config.en.apk and split_extra_icu.apk) ? or just the base.apk?
my extreme apologies bro.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by ngankvn View PostMy box has the serial number: C922HQBG ... can I use this rom?
Any advice or links??
Would be greatly appreciated.
Andrew
Originally posted by Savuti73 View Post
Hi there , I have a Gt King Pro SN:C922HQBG90248 I am looking for the correct Android TV Rom to download, Android TV not stock Android.
Andrew
Please read the entire first post on the thread before you flash your box.
Thank you,
Alvatech
Link to King Pro ROM ATV:
Originally posted by viggen66 View PostDear all,
I know this is annoying, asking always the same, my king pro has serial number SB9HH0LF, which trimmed equals to SB9H, which custom rom appropriate for it?
Thank you,
Alvatech
Originally posted by ALVATECH View Post
The first post of the thread states "Made two different ROMs one for the GT-King Pro with SN:922H and then all the other GT-King Pro boxes can you use the GS-King X ROM. It also states "Download ROM for all other GT King Pro boxes and GS King X:" next to the download link for that ROM. The 922H has its own ROM due to different power management. So you would use the other one. I will update the first post maybe with specific SN to make it easier.
Thank you,
Alvatech
Once again thanks for all the work, I never liked stock roms on Android boxes.
Originally posted by viggen66 View PostThanks this way clears all the doubts, just one question does your rom has ads blocker?
No, I did not include this in the ROM. You can add as needed.
Thank you,
Alvatech
There are currently 4910 users online. 0 members and 4910 guests.
