which rom should I use?
[ROM] Beelink GS-King X & GT-King Pro ALVATECH Standard Android (9.0 Pie)
Hello everyone,
It has been a while. I've been pretty busy with lifestyle changes and other projects. I've updated the first post with the latest ROM from Beelink. I hope you'll enjoy the new updated ROMs. I don't have as much free time as I use to, so please try to help each other with any questions in my absence. I hope to update the 2nd post with some updated info on how to pass safetynet. Also, to fix a screensaver bug I've just noticed at the last minute (I'll give instructions on how to fix it pretty quickly). I hope to release Android TV ROMs next for these boxes.
Stay safe and thank you,
AlvatechLast edited by ALVATECH; 01 December 2020, 05:29.
Tomorrow i will receive mine (Pro).
Some questions: It is true that the cables for BT and Wi-Fi inside are in wrong position, or crossed?
Alvatech
Unfortunately my "old" Beeling GT did die, due hardware mods i made....but your rom was perfect!
I read your section about Magisk. Seems more complicated thank install for Beelink GT or even a phone, since i do not now how to use Terminal...
Any possible way to simplify this part?
I want install a program from cable provider and the dam thing refuses to install on rooted devices....
Can`t wait for tomorrow and try this.....
P.S: Some devices came with CPU speed reduced.....whats the program to check the true speed? Also, is possible overclocking if it has only 1.7Ghz?
Thank you in advance!
Some updates:
Did install successfully this rom, no big issues.
Problems:
Can`t install Nova. Or i can, but can`t move icons.
Wi-Fi doesn't work. Unless i remove Ethernet Cable. Weird.
Magisk is too much complicated...i will pass.
BT....can`t say so far if it works.
Seems to read somewhere there is a problem with hardware and Ethernet board resistance?
Can someone share here information?
Hello everyone,
I have updated the 2nd post with some updated info on how to pass SafetyNet and a few other tips. I have now released 2 different types of ROMs one being Standard Android and the other one being Android TV. Thank you everyone for all the positive vibes/feedback and also donations I really appreciate it.
Alvatech
Hello,
I have released a ROM specifically for the GT-King Pro with SN:922H, for those of you who may have had the issue of the box not staying shut off. I appreciate you Tsunarun for testing this out for me. Please see the first post for an update on this specific box.
Thank you,
Alvatech
Hi can we mount rclone like Google drive on GS-King X? I used this tutorial: https://android.stackexchange.com/qu...one-on-android But it didn't work.
This ROM is working very well for me so far, on my Beelink GS-King X, but I'm having just one problem: the navigation bar is closing and opening (crashing, but without any popup, and the homescreen wallpaper flashes).
From what I can see, it happens usually when I go to homescreen, by pressing Home using the remote controller. If I use the buttons on navigation bar (home/back/recent apps), the navigation bar is most likely to crash, and the action was not accomplished (I have to use the button on remote controller).
Is there anything I can do to fix the navigation bar?
I'm using Google Now launcher, but it is also happening with the original launcher.
Originally posted by Rani2add View PostI tried the rom for SN:C922H & SA9H but no wifi
There are currently 1392 users online. 0 members and 1392 guests.
