rk3229 chip box
Originally posted by charan View Posti tried some loaders , some of them flashes successfully , but the box dosent turn on after completing flash
did you not read that they not fit your Box , i extra edit the Text for this , few minutes later i saw it , stop flashing wrong loader , what loader Version is used on this bricked RK3229 PCB ???
without you must not start ,
greetings / gefattern
by usinng this loader i get "prepare idb failed"
please listen , to restore you must use the Haizenberg Way , like he explained , not like you did flashing all parts , only loader and it must be the correct RK3229 loader , that before the Box bricked was installed ,
which Loader Version was it ???
good luck / gefattern
i used that method of shorting GND and CLK but the result is same.
i dont know which was previous loader file.
now im using loader file of MXQ box,
Hi ,
https://drive.google.com/file/d/1NA5...ew?usp=sharing
listen , dont know what you are doing , think , the idbloader part is bricked & cant restored ,
as more you flash different parts , as more bricks , maybe you can restore some of your bricked
Boxes with the SDCard Way , later i can upload , again , the SDTools & you can try this , further i cant
help , because i am only Moderator , not Developer , i try to guide the Users the right Way , if i can ,
further good luck / gefattern
only android logo comes up and then goes into recovery mode
Originally posted by charan View PostBox enters recovery mode, after using sd card
one is for booting from SD , the one with only SDboot.bin , the other Tool is for flashing with SD , the one with 3 Loaders inside Folder , some say you must press Reset , for 3-4 seconds while plugging in Power , then leave , but i think this is not needed , my Hint for you , dont buy unsupported cheap
MXQ or other shit , buy better supported Devices like , UGOOS , Beelink or similar ,
There are currently 2259 users online. 0 members and 2259 guests.
