TANIX TX6S Allwinner H616 Android 10.0 TV Box 2GB/16GB 2.4G+5.8G WiFi LAN Bluetooth
You have the box TX6S yet?
Is it possible for you to make any Backup file in stock recovery which i could use in recovery which i can access to try to restore my SystemLast edited by tombraga; 01 February 2020, 09:27.
Originally posted by tombraga View Postsparky57 could you use the app which i uploaded for you? with this app you should can reboot to stock recovery...
i sent you also an information, that on my box the hole for the stick to boot in recovery is beside the SPDIF connection and not beside the TF sdcard slot.
As it is, even with a stock box it's useless. Tannix did so little work on android 10 and their hardware it's ridiculous.It's also pathetic that Tanix has no human interface with the public. It's fine though, many others make devices. X96 and beelink will do just as well.
The 5g network not working, really ? Back to the drawing board and I want some money back.
Tom wait. I wanted the build.prop, because i thougt i can boot with sd card and Libreelec and then copy your build.prop to my system. But the sd card is not booting, because i tried with TX6 image file, but did not work.
so i can not use your file, but have to wait for firmware...too bad.
but thanks for your offer
There are currently 2549 users online. 0 members and 2549 guests.
