TANIX TX6S Allwinner H616 Android 10.0 TV Box 2GB/16GB 2.4G+5.8G WiFi LAN Bluetooth
Originally posted by gksureshkumar View Post
Thank you for your tip Mr.MartaN. Can you please explain how to copy the zip file to SD card root directory. How to go Root directory of SD card
2. Reboot into recovery as mentioned before. With the toothpick trick, while the USB Stick is in the lower USB 2 Port !!!
3. Go on "Apply update from SD-Card"
4. Take the first entry (for me it was the needed USB Stick)
5. You will see the update.zip
6. Choose this file and let it install
7. You will have to wait some minutes. The box reboots and will reboot into system (about 7-8 minutes or so)
8. i forgot
Happy flashing..
Originally posted by MartaN View Post
Hi Javimetal so ...S/N: CSH616P63C0074-H
Working also in replacing ATV Play store (provided by AllWinner) to the usual one.Android TV Box direct from China. English & EspaƱol
Originally posted by TheRealDeal View Post
1. You need to copy the update.zip on a USB-Stick because the sdcard is not recognized as such (but the stick). Root of the stick is nothing special. Just copy the file on an empty stick
8. i forgot
Happy flashing..
Dear friend Thank you for the inputs. I will try today and update about the outcome.
Then i inserted the USB stick to the lower USB 2 port
I pressed the tooth pick in the reset button and inserted the power cord to go to recovery mode
I could not able to open the recovery mode even i waited long press with tooth pick and power plug insertion. i saw only TX6S logo
in the TV screen. I tried serveral times tooth prick press with USB stick inside and then power plug insertion then
recovery mode is not starting at all. If it goes to recovery mode then i can apply update from USB stick but
i could not able to reach that stage. Please help
Originally posted by tombraga View PostCould you feel a light klick when you pressed the tooth Pick? It's a little tricky to hold this down enough time after connect the power.
I use always a paperclip, more stable as wooden tooth Pick. But must use carefully and soft pressing.
2. After managing this fuc**ng toothpick trick and how to hold it, put the usb stick in your box.
3. Put the toothpick in and hold it
4. Plug in the power
5. Hold the toothpick / needle...you will have to wait until the recovery is shown while holding the toothpick (7 - 8 seconds or so)
If this all not works for you, your recovery is broken also (whyever ?!?!?!) or you should let a friend of you, who is technically experienced than you do this...
1. First of all, test this without anything plugged in. No power, no usb stick, nothing. You should feel the click (and hear it). Test and learn how to hold the paperclip / needle or whatever you use for it for a while
No luck at all. I tried the paper clip to press. I can feel the clicking ( i heard it). After following this procedure recovery mode does not start. As you mentioned my box recovery also broken it seems. This TX6S Box is unusable now.........
New update is come on http://www.tanix-box.com/download-vi...h616-original/
with differences by serial number
UPD
Tanix confirmed that the update is only for serial 001-250. For other serials, the update will be, but not yet ready.Last edited by Turkmenator; 25 February 2020, 21:25.
Originally posted by Turkmenator View PostNew update is come on http://www.tanix-box.com/download-vi...h616-original/
UPD
Dear friend
If you have a knowing person in your neighborhood you could try to shorten the nand. But please... this is very dangerous for your box and should be done by a specialist. I had same problems with a TX3 and a friend solved the problem. Here is an image what and where he shortened the nand.
Sorry to hear it, but perhaps you should wait untill anybody creates a TWRP Recovery for the TX6s. After you should have the chance to boot via sdcard into TWRP and flash the update.zip.
There are currently 3618 users online. 0 members and 3618 guests.
