Way to confirm is with a file manger look at all the package names for the system apps of a stock ROM and you may see things like : com.oranth.tvsettings
TANIX TX6S Allwinner H616 Android 10.0 TV Box 2GB/16GB 2.4G+5.8G WiFi LAN Bluetooth
Originally posted by belloto View PostThis firmware is much better, but i not be able to install ANDROID TV version apps, for me, only mobile versions works.
I've installed Netflix, Movistar+, Disney+, Prime Video and KODI. Prime Video doesn't work in any version, the other apps only in mobile version.
The OS is very slow, but is better than last version.
What's happen if I install this file: https://mega.nz/file/yqhFzA4Q#T7b6ns...qV5X1L_TG7_SuE
The format is equal to update.zip from Tanix in the previous update. RiCkLaR_atvX, have you tried to install?
Thanks.
When installing an OTA.update.zip the date of the build number must be newer then what is installed into device. So if you are on a March firmware you can't flash the January OTA because the system will see the date and deny installation because it is older version.
Originally posted by RiCkLaR_atvX View PostWhat firmware you describing? Date?
Hmm, did you upload this to Mega yourself? I didn't see it being shared on Mega yesterday when I tried to download that firmware.
No. That mega link is from androidpc.es. i didn't know that the OTA date would must be newer than the installed one so...., Is there a box with this hardware and a newer software version to check?
Originally posted by c,lei View Post
This is precisely why companies are locking down the firmware on their devices, to keep guys like you from screwing up other people devices by passing around firmware you shouldn't be. Can't say I can't blame them after seeing stuff like this either. Dude if the firmware is not meant for your device, *DON"T SCREW AROUND WITH IT* especially if you don't know what the hell you are doing. Why the hell would the new OTA fiirmware date be *OLDER* than the firmware that is already installed on the device? That alone should tell you not to install the firmware on your device, especially if you didn't get the firmware from the people who made your device.
I don't say that you have to install this or other firmware in your device, I only wanted to know what possibility would there be to install a different software y the same hardware.
You can do what you want, of course.
Thanks.
Be calm man. I only want to use my device so, i'm looking for alternatives.
Thanks.
Like I said, I'm starting to have no problems with the manufactures locking things down and once again requiring people to actually know what they doing before allowing them to flash the firmware on devices. If that make installing custom firmware difficult,so be it.
Originally posted by belloto View PostI'll check tomorrw. Thanks.
What about this?
Firmware disponible para recuperar el TV-Box T95 con el SoC Allwinner H616 que integra procesadores ARM Cortex-A53 y una GPU ARM Malí-G31 MP2. De este Smart Box hay versiones con 2/4GB de RAM DDR3 y 16/32/64 GB de memoria de almacenamiento eMMc que podemos ampliar gracias a el lector de tarjetas microSD que incluye este
What's your opinion? Thanks
Going to have to wait and see if Tanix release a better update.
I was wrong that T95-H616 firmware is not compatible, I tried using that firmware, it installed no problem, but device won't boot, you get stuck on the T95 Boot splash screen.
Originally posted by mickyari View PostBqeel B1 max firmware and Primevideo and Netflix modded apps? The question is the compatibility...
For those apps and TX6s or clones of same device, then don't buy it!
Big problem TX6s (chime every 30 seconds) with the new update 4.9.170 of March 17, 2020 I searched 3 hours I can not find the config (audio notification) helped me please
???????Gros problème TX6s (carillon a toute les 30 secondes) avec la nouvelle mise a jours 4.9.170 du 17 mars 2020 j'ai cherché 3 heures je ne trouve pas la config (audio notification)
Originally posted by Pierre Rousseau View PostBig problem TX6s (chime every 30 seconds) with the new update 4.9.170 of March 17, 2020 I searched 3 hours I can not find the config (audio notification) helped me please
There are currently 1069 users online. 0 members and 1069 guests.
