TANIX TX6S Allwinner H616 Android 10.0 TV Box 2GB/16GB 2.4G+5.8G WiFi LAN Bluetooth
Originally posted by webipsum View Post
Did you photograph your step-by-step?
Tks. RiCkLaR_atvX
Johnoo , one more question:
What is the operating temperature of your X96 Air S905x3 with SLIMBOX?
Tks.
hai
solutions
ATV Transpeed_H616 Android 10
https://mega.nz/file/ORhXURLb#JNYIaM...DkBsJXxxhqmZZE
thanks you developer OT.DO 4pda.ru
Tks.
Originally posted by Johnoo View Post
Temperature is non issue with S905x3, while streaming 60 to 65c, seen it max at 75c doing something more intensive.
My A95X F3 temperature:
Initial: 62º
Running 720P / 1080P (YOUTUBE): 68º / 69º
Running 4K (YOUTUBE): 74º / 75º
Enviado de meu SM-A710M usando o Tapatalk
Originally posted by bruski View Posthai
solutions
I noticed it is smaller 460mb as compared to that which is provided by Transpeed 1.6Gb in the Google drive below.... which is also not Google play certified..
https://drive.google.com/drive/u/0/m...ip&ts=5f553eb3
Originally posted by Boxer View Post@wepipsum- I have no account at Amazon Prime but using other paid streaming apps without problems (needing non-rooted device)
- Google Assistant is still not receiving your voice through the RC similar to the Tanix ROM
- Got fed up playing around optimising different launchers so I haven't tested. But according to previous statement other launchers seems to work.
The broom button lets you decide what apps to kill etc.- What is the current status of your TX6S with Transcend firmware?
- Do you use the Disney + stream service?
- With Transcend firmware can you access the navigation bar and the notifications bar?
Originally posted by Boloksbongas View PostIs this Rom finally Googleplay certified?
If you want to get a "Google Certified" device that has AndroidTV then you will have to pay more $$$ for devices like the Mecool KM1 or Xiaomi Mi Box S that are certified to run Google's AndroidTV rom.
Originally posted by RiCkLaR_atvX View Post
Generic Chinese Android TV boxes are not "Play Protect certified" if that is what you are asking, and they can not be made certified by changing the ROM.
That doesn't answer my question though....
Do some research.....Last edited by Boloksbongas; 16 September 2020, 23:31.
The ROM is about 1.2 GB when decompressed and is running lean with few apps. The installation took about five minutes with PhoenixSuit compared with normally1.5 min. It looks like the Mekool ATV interface with a functional Google assistant (mic is working) and the desktop is configurable with the channels of choice through the Android settings menu. I couldn't get ATV Google Play store working properly maybe due to login problems... Not very keen on the ATV format myself though.
Would give this a go and see how it pans out...
Originally posted by webipsum View PostHi.
My Tanix TX6S: 95º
What solution are you using to lower the temperature?
Tks.
Here, my TX6S, still has the same high temperature problem.
What is the average temperature of your TX6S?
Tks.
Originally posted by webipsum View PostFriends, please, are you having high temperature problems with the TX6S?
Tks.
There are currently 3751 users online. 2 members and 3749 guests.
