Necessary to update with latest official tanix firmeware
https://dailyuploads.net/p5ldtuz00v24
https://chinagadgetsreviews.com/?s=tx6s
updated
enter the recovery screen = insert a clip in the hole behind the box next to the 2 usbs and turn on the power source
Da um = wipe data Factory reset
Da um = Wipe cache partition
then restart the box
download this version of Magisk Manager 8.0.2
https://www.4shared.com/mobile/51Kc4...omtopjohn.html
install
With wifi enabled in the box opens the Magisk
click Install and choose = Direct install (Recommended)
click Lets go = Go now
Wait for Flashing and Restart
when starting check if the Magisk is as installed by opening the apk
install Root explorer pro
https://www.4shared.com/mobile/amLDg...tExploler.html
Because we will need it
and test if everything is working with root as the root permission screen should appear
(((Now let's go to the cat's jump so you can change the System folders)))
simple
Open the rootexplore apk
give root permissions
and on the tab = root = on the left side of the window "" MOUNT R / W ""
It has the size of the partition and how much space is left in the partition
so there is the problem
little space to install more files in the folders, and as there is not enough space of the FAILURE
Change the "MOUNT RW" window to "MOUNT RO"
then you go to the apk preinstall folder
and uninstalls less important files like apks
to increase the space left on the partition
can go to the tab "APP" AND UNINSTALL yotube
when you have about 180 mb of space you will be able to install files on the system without errors
after making the ATV modifications you install the apks again but now outside the Android system partition
follows video of my TX6S with original Rom TANIX
https://www.youtube.com/watch?v=vn86...ature=youtu.be
Good luck to everyone
