TANIX TX6S Allwinner H616 Android 10.0 TV Box 2GB/16GB 2.4G+5.8G WiFi LAN Bluetooth
Guest
Originally posted by webipsum View Post...Certainly, manufacturing defect...
Originally posted by RiCkLaR_atvX View Post...found the Heatsink thermal-pad not positioned correctly on the CPU, maybe losing 15-20% of CPU surface area not covered because the pad was installed crooked, but be careful if you yourself want to open this device because the top is really resistant to being removed...
Radical? What do you mean?
Only way to really lower the temperature is to use an external USB fan.
I see @RiCkLaR_atvX & @mAtvXk here, are you guys working on an atvexperience version for this box? whats the closest I can get to that at the moment?
Originally posted by sahibji View PostI see @RiCkLaR_atvX & @mAtvXk here, are you guys working on an atvexperience version for this box? whats the closest I can get to that at the moment?
Sadly if you have this box I am sorry....stay far away from it.... I would say return it or give it away and get a better box lol. The H616 chip is worst than the RK3318, I hate it.
No atvX is NOT being made for any other chipset brand, except for the stable Amlogic chips.
https://mega.nz/file/ORhXURLb#JNYIaM...DkBsJXxxhqmZZE
But as always burning ROM's is on your own risk with possibility to brick your device.
Originally posted by Boxer View Post
To answer your question and being stuck with this box the closest to ATV experience is probably this ROM:
Thank you so much for your reply, unfortunately, that file is no longer available for download. If you know the name of the firmware I can try to find it elsewhere?
Originally posted by bruski View Posthai
solutions
ATV Transpeed_H616 Android 10
thanks you developer OT.DO 4pda.ru
Originally posted by webipsum View PostI asked this question in the thread on the A95X F3:
I would like to extend this question to friends who own the TX6S:
Is anyone successfully using Disney+ on the Tanix TX6S?
Tks.
sorry my bad english i'm using google translator
in time I'm struggling with this H616
On my TX6S XGODY
all ATV rom has volume key failure on original control
and as root does not work on android 10 I have no way out to fix this bug
follows some ATV rom for peer testing
2x16
https://mega.nz/file/WJJkQAgb#e1DYf4...bRZgZ6MBrmap9A
all versions
https://mega.nz/file/XdRw1TQB#u1piyE...cvB72PzdoPQeoE
rom native
https://drive.google.com/drive/u/0/f...dQ13kcYWqgMn2M
T95-BASED ATV FOR ALL VERSIONS
https://mega.nz/file/WARQyJpI#k0ekvK...1yTebOUfTEFASs
hugs to allLast edited by bruski; 16 October 2020, 16:40.
There are currently 2921 users online. 3 members and 2918 guests.
