TUREWELL T95 Max+ Firmware Download Link
Originally posted by ahbecan View PostOfficial download website :
https://www.turewell.com
I have t95max plus. rooting is big issue, but i have boot image patched by magisk that works.
It indeed roots stock firmware but the front led becomes useless.. but it works.
also twrp temorary works good for this firmware , by avoiding installing it to recovery img.
just install from stock recovery and it will be one time instance.
(still trying to figure out front clock display issue.. think it has to do with dtb/dtbo patching that magisk does)
boot into twrp via recovery (or update app)
patch boot img
install magisk zip
T95_X3_PlusS905X3_Magisk_Patched.img
TWRP_322.zip
Magisk-v20.4.zip
Originally posted by killerjosh View PostI have t95max plus. rooting is big issue, but i have boot image patched by magisk that works.
patch boot img
install magisk zip
TWRP_322.zip
Magisk-v20.4.zip
https://www13.zippyshare.com/v/JHDNI7Tk/file.html
have you installed drivers and which usb port on box are you using? i used amlogic 3.1.0 currently.
theres probably tutorials elsewhere but I will give you a simplified one for this box...
Unplug everything.
Press and hold reset button (av hole)
using usb 2.0 port on box. black plug not the blue one plug into computer and amlogic should detect almost immediatelyLast edited by killerjosh; 07 August 2020, 01:51.
Originally posted by Tactic_thomas View PostI attempted to flash the rom but was unable to get the box to connect to amlogic flash tool is there a certain version or driver i have to use?
Originally posted by drsam007 View PostI have ported SC2 ROM (userdebug version based on ATV) to T95 Max+. You can download it from:
I have flashed it to my box using AMLogic USB Burning Tool 2.1.9, and I don't see any issues, but I am not responsible if it bricks your device.
Originally posted by DaMeZ View Post
There are currently 1516 users online. 2 members and 1514 guests.
