RK3328 Firmware Center RTL8723 , AP6255 , SV6051 , IT6334 AND MORE (Stock-ROMs , Custom-ROMs by Silver)
Hello, I have an MX10 PRO with MXQ RK3328 D4 board v1.3 20180306 and on the wifi bt chip it says HK6334Q and I don't know what the firmware is, I have placed several of H6 MAX and HK1 MAX and they work without wifi and without bluetooth. what is on the net for that model does not work, it remains unbrick. any suggestions I appreciate
Originally posted by klinyermont View PostHello, I have an MX10 PRO with MXQ RK3328 D4 board v1.3 20180306 and on the wifi bt chip it says HK6334Q and I don't know what the firmware is, I have placed several of H6 MAX and HK1 MAX and they work without wifi and without bluetooth. what is on the net for that model does not work, it remains unbrick. any suggestions I appreciate
Originally posted by Silver View Post
ou can try to backup the boot kernel and resource iMG of stock rom and try to boot my rom with it.
the problem I have to make the copy is that when trying to get the parameter.txt with rk android tools 2.39 putting 0 in start and 2 in count the file it generates has nothing but nonsense letters, I have looked for another way to generate that file since they lent me an mx10 pro, the pcb and the wifi chip, but I can't find a way to make a backup. maybe you can help me
a copy, it does not matter that I have flashed with another firmware?
Good morning, I would like to tell you that I managed to make the copy of the other mx 10 pro I did it with rkDumper_109_test because it is RKFP format and I have the copy but I can not put it in the other with rk android tools if flashing is in maskrom mode I do not know what else to do some idea
how could I pack everything in one img to flash with factory tools
Hi Silver I flashed my box with rk3328_d4_7.1_rtl8723bs_20180705_r1_root but it's not booting
my box is T9 RK3328 4GB-32GB with the wifi device driver rtl8723cs
I have flash it back to the stock ROM http://www.mediafire.com/file/cy29o5...B32GB.img/file
what I want is to install Magisk, I can't install it on the stock ROM, want to try to install it on your custom ROM.
Originally posted by Famous View PostHi Silver I flashed my box with rk3328_d4_7.1_rtl8723bs_20180705_r1_root but it's not booting
Its a test rom you cannot expect it to work on every rk3328 device.
Originally posted by hrrom View Postwith firmware rk3328_d4_7.1_ap6255_20180705_r1_root.img freeze on black screen. with rk3328_d4_9.0_rtl8723bs_20181128_r1.img start but wifi not working. Please can you build .img rk3328_d4_9.0_ap6255?
There are currently 2891 users online. 0 members and 2891 guests.
