RK3328 Firmware Center RTL8723 , AP6255 , SV6051 , IT6334 AND MORE (Stock-ROMs , Custom-ROMs by Silver)
Originally posted by Silver View PostI have seen many users bricking their RK3328 TV box with incorrect firmware.
In this thread i will supply some IMG files for you all so you can reflash your box with working wifi/bt drivers
This includes 2 firmwares i have customized with preinstalled apps some patches and root
The CPU frequencies have been changed based on wifichip kernel. You can tweak CPU with Kernel Auditor.
Do note the RK3328 CPU and MALI-450MP GPU are not suited for multitasking nor gaming, best usage is for streaming using apps like youtube ect.
Box may run HOT depending on flashed firmware.
RTL8723BS: 2016MHZ max.
AP6255: 1500MHZ max.
OTHERS: 1300MHZ, 1800MHZ
rk3328_d4_7.1_ap6255_20180705_r1_root
rk3328_d4_7.1_rtl8723bs_20180705_r1_root
Changelog:
-debloated
-SuperSU root (do not update SU binary)
-Preinstall apps (Launcher, Kernel Auditor, Navigationbar, Gboard, FTMC, YoutubeVanced, XposedInstaller ect.)
-Fix Autoframerate in FTMC
-Fix WallpaperService
-Fix missing menu in some apps (3dot menu)
-Fix apps crashing
-Patched recents for normal view
-Build.prop tweaks
-Wifidriver tweaks
Notes: i cannot fix these issues i am not the manufacturer
IF FTMC not installed, open calculator app and input chinese "PI" symbol followed by "318" so "PI318" (just make sure it shows the symbol instead of "PI"
Some USB ports may work unstable with certain peripherals on these ROMs.
RTL8723BS wifi module unstable if bluetooth enabled and using Bluetooth mouse for example
Possible more bugs but nothing dramatic, these are chinese tv boxes you cannot expect everything to work perfect
Downloads for custom ROMs by Silver:
AP6255=
https://mega.nz/file/blUnEAjL#Aw5O4t...qbaUwQha-QTIX4
RTL8723=
https://mega.nz/file/78ETTCaQ#TSfQe7...0BaPiD08pieONM
You can send me some cookies if i helped you= 1NMaX2Y2P1XW6UYhQCWwzVp2qEvekoGhBZ
ATTENTION: I am not responsible if you brick your box because you flashed wrong firmware!
Prerequisites:
-Backup your current working ROM if anything goes wrong (You can use RKDumper for example)
-Understand how to flash your TV Box with AndroidTool or FactoryTool
Firmware Description:
CPU_BOOTLOADER_ANDROIDVERSION_WIFICHIP_DATE_{ROOT}
example:
rk3328_d4_7.1_ap6255_20180705_r1_root.img
Try different versions of AndroidTool and FactoryTool before posting errors here!
I have tested all firmwares and they run fine.
Stock Firmwares and files:
https://mega.nz/folder/ehN22SqI#tcS1v8TaCCk4wi0J__Jv_A
Notes: i have included AndroidTV firmware (Widevine L1 is blacklisted sorry) also includes rooted boot.img so you can try to root your android 7.1 firmware with it.
IT6334=
flash:
https://mega.nz/file/ihcgjChC#xwjrrr...aCSYuDu-BHczI4
Note: Box will not boot you have to flash IT6334 patch i have uploaded
https://mega.nz/file/v5UQVQgI#jh7cPV...63TZ59Pqxu2kAU IT6334 patch (use AndroidTool load the provided config select and flash all images in your box)
Confirmed working on:
MX9Pro
Mx9MAX
A5XMAX
MX10
V88 Piano
...more to come
Here are my steps to flash the firmware from 'Silver' (rk3328_d4_7.1_rtl8723bs_20180705_r1_root.img) :- Install Rockchip_DriverAssitant_v4.4 or v4.8
- Open "rkdev tool - AndroidTool_Release_v2.51" and goto 'Upgrade Firmware' tab
- Click 'Firmware' and locate the img file
- Remove screws of the TVbox. Refer to the image attached below and find the copper dots which are necessary to short-circuit to enter MASKROM mode.
- Use a wire or a conductor to connect the two dots. While doing that, connect the male-male USB cable to PC and USB 2 port of the tv box. AndroidTool will show "Found One MASKROM Device" immediately. Remove the Short-circuiting conductor.
- Click 'EraseFlash'
- Click 'Upgrade'
- After the upgrade is finished, remove the USB cable.
- Connect HDMI cable
- Connect power cable (sometimes, you might have to hold the av-reset pin before connecting the power cable. but I didn`t have to do that)
- Boot animation will appear within few seconds. If the display goes to standby mode, remove and replug the power cable.
- the android logo will appear. then wait.....
- Done !!!
- Let me know if this helps.
Please test firmwares and reply back here so others know what works for what box.
-Silver
There are currently 2094 users online. 1 members and 2093 guests.
