Thank you!
[ROM] Tanix TX5 Plus S905X3 Android 9 Stock Firmware IMG
Guest
Originally posted by Solace View Post
Please explain how you managed to flash this specific image? SDcard method did not work and USB burner fails to load the image even when disabling image checks.
Dude... as I said, I'm not coming on this site to be called a liar or an idiot, I told you I have tried this on numerous machines (unix, osx and windows) without any problems what so ever... leading me to believe it's your end with the issues... no one on here seems to have the issue other than you.
Guest
Originally posted by Turvy View PostAre these boxes discontinued, or not on sale to Europe?
Originally posted by mAtvXk View PostSold out on french Amazon, in stock on other two's.
All along I have used H96Max X3 firmware for this box. There was one with June 2020 date that I have first installed working fine. Recently there is an update with August 2020 date "u215.H96Max_X3_1000M_9.0.2020.08.12.18.05" for this Tanix TX5 Plus S905X3 box and everything is working fine as well. Ethernet, Wireless, Bluetooth etc... I never use the remote coming with the box so I don't know if it works or not. Anyway, I strongly recommend using a wireless or bluetooth mouse.
The firmware is in .IMG format and has to be flashed with USB Burning Tool included in the link. This is the link from where I have downloaded the firmware : https://drive.google.com/drive/folde...-TPyiK236-Hu1f
Originally posted by ALdelSol View PostWell, I have installed the rom that you say about the h96max x3 and in my tanix tx5 plus neither the wifi nor the bluetooth, nor the remote control and ethernet work, I don't know because I have not tried it and it also deletes the recovery. Come on, a mess.
Brand Model: H96 Max X3
——Amlogic S905x3 Android 9.0 ?Download?
Estoy seguro de que tengo el Tanix tx5 plus delux edition con 4 ram, 64 almacenamiento y 1000 ethernet. Los que sí funcionan son los del x96 max plus en los que lo único que no funciona es el reloj y el mando. una pregunta: ¿alguno de ustedes ha logrado instalar magisk en esta caja tanix? Por mucho que parcheo el boot.img, lo flasheo y no se puede lograr la raíz.
el x96 max plus que instalo es el que tiene 4 gigas de ram, no el que tiene 2Last edited by ALdelSol; 11 November 2020, 11:16.
Originally posted by ALdelSol View PostEstoy seguro de que tengo el Tanix tx5 plus delux edition con 4 ram, 64 almacenamiento y 1000 ethernet. Los que sí funcionan son los del x96 max plus en los que lo único que no funciona es el reloj y el mando. una pregunta: ¿alguno de ustedes ha logrado instalar magisk en esta caja tanix? Por mucho que parcheo el boot.img, lo flasheo y no se puede lograr la raíz.
2. Since you are interested in Magisk did you finally try my custom rom where Magisk is preinstalled?https://forum.freaktab.com/forum/tv-...amlogic-s905x3
From your post there I don't have such an information (or I didn't understand it fully).
Originally posted by ath156 View Post
1. It would be good if you would write in English and not to have to use translation.
I'm sorry to use the translator, I only know Spanish and bad ??. I wanted to say that I, in tanix tx5 plus I can install firmware of the X96 max plus box with 4 gigs of ram without errors beyond the command and the clock. I also have the problem of rooting with magisk with the original Tanix firmware because it doesn't really patch the boot.img. I have its firmware installed in my other h96 max x3 box because its performance is really good and also with magisk.
There are currently 2169 users online. 1 members and 2168 guests.
