[ROM] Tanix TX5 Plus S905X3 Android 9 Stock Firmware IMG
Originally posted by ALdelSol View Post
Originally posted by warzouing View Post
You have mentioned that you have "Tanix TX5 Plus Deluxe Edition", i guess the one with an external antenna. That is probably why the firmware for "H96 Max X3" does not work on it. Mine is just Tanix "TX5 PULS" as shown on the sticker, without an external antenna and the 2 of them were bought December last year from Amazon. Network chipset migh be completely different.. One thing I have learned from those boxes is that you have to try many firmwares before finding a good one that fits yours.
you're right, my box has an outdoor antenna.
Has anyone managed to patch the boot.img with magisk on this box and get it to work? I'm thinking that this is mission impossible, no matter how hard I try, I can't make it work in any way. Magisk says it has patched it but when I install magiskboot.img on reboot nothing happens or installing magisk right after boot.img
Originally posted by ALdelSol View PostHas anyone managed to patch the boot.img with magisk on this box and get it to work? I'm thinking that this is mission impossible, no matter how hard I try, I can't make it work in any way. Magisk says it has patched it but when I install magiskboot.img on reboot nothing happens or installing magisk right after boot.img
Originally posted by RiCkLaR_atvX View Post
On a factory Amlogic ROM you install Magisk into the Recovery.IMG -- extract recovery.img file and patch it as "Recovery Mode" -> then flash it with TWRP by installing the magiskboot.img file to recovery partition -> reboot.
I have tried the method you have recommended. The recovery is patched, I already have magisk but what I do not have now is the recovery, the box does not start on it.
Originally posted by ALdelSol View PostI have tried the method you have recommended. The recovery is patched, I already have magisk but what I do not have now is the recovery, the box does not start on it.
By the way, just to let you all know that i'm extremely satisfied with the latest official firmware from "H96 Max X3" flashed on my "Tanix TX5 Plus, 4GB/64Gb/Dual Wifi/1Gb Ethernet", the one that came out around November/December 2019 on Amazon, not the one being sold right now with an external antenna and marked "Tanix Deluxe Edition".- Root can be controlled in settings
- Performance seems to improve
- Wifi is working, same as Ethernet wired connection
- Bluetooth working
- Flashing this firmware get rid of Tanix Alice UX launcher. The launcher coming with it can be easily changed. I'm using Nova Launcher
- And last but not least, navigation bar and notification bar have been recently added on the latest firmware dated 2020/10/16. Can be set to on/off in settings.
- I never used the remote coming with those boxes, only wireless mouse so that i did not test it. Anyway, i don't know which is which anymore as i have so many of them lying around.
Originally posted by warzouing View PostBy the way, just to let you all know that i'm extremely satisfied with the latest official firmware from "H96 Max X3" flashed on my "Tanix TX5 Plus, 4GB/64Gb/Dual Wifi/1Gb Ethernet", the one that came out around November/December 2019 on Amazon, not the one being sold right now with an external antenna and marked "Tanix Deluxe Edition".- Root can be controlled in settings
- Bluetooth working
I even made my own custom rom https://forum.freaktab.com/forum/tv-...5x3#post812507
which among other options (upper/lower bars, notification bar,samba server etc) has Permanent preinstalled Magisk and permanent TWRP.
I agree with you that the last firmware for H96 Max X3 (dated 16/10/2020) is very good and at last they decided to enable some options that users usually ask for (like navigation & status bar, root switch, etc).
But, in my opinion, there are still some other custom firmwares better than this (good as I said) last firmware of H96 max X3.
Originally posted by ath156 View PostI own an H96 Max X3 from February 2020 and I have tried every possible firmware for it until today.
Correct, no more internal recovery if you install MAGISK on Amlogic. So, to use Recovery you must use a Portable version of TWRP that is in zip format on SDcard or USB-drive that can be loaded with the Update app to launch the Portable TWRP file. Try using this TWRP : https://telegra.ph/Temporary-TWRP-09-12
Thanks for your recommendation, now everything is working without problems
As you know, i already installed your rom on my HK1 and i am very happy with your rom, working perfectly, thanks.
Once you know these 2 pins you can use a temporary TWRP to backup your BOOT, SYSTEM, VENDOR and DATA partitions.
Having this backup you can try any other firmware you like or easily revert back to your current state.
tombraga
Maybe this will help you https://forum.xda-developers.com/t/r...#post-84073807
(of course I still insist in knowing the 2 "magic" pins - just in case !!!).
There are currently 1983 users online. 0 members and 1983 guests.
