[ROM] Spartan_ROM ATV S922X
    Dev, i flash again using this rom as I wany to try something and I noticed that the WiFi gets weaker by using this ROM, compared to Alvatech ROM.
    UPDATE: regarding the WiFi CONNECTIVITY issue, its also an Issue using Alvatech , its a Hit & Miss so I decided to Disable the Auto Reconnect the VPN on Reboot.
    I have flashed mybdevixe uaing SPARTAN to use the Wolf Launcher, I have already installed it but it needs to use a Button Mapper for the Home Button & Root Uninstaller to Disable the AndroidTV ? Home.
    it doesn't give an option if what Launcher should I use.
    Sent from my GM1910 using Tapatalk
      UPDATE:
      SPARTAN ROM is not Connecting to 5Ghz WiFi,
      this ia the reason why I get a weak signal base on the indicators.
        UPDATE:
        check your router settings and stop spamming my thread i dont have an issue one bit your the only one complaining about it
          its called feedback not spamming.
            I have been testing the 5Ghz WiFi connection for another individual, and it is working perfectly for my Beelink GT King Pro......... I am watching "A League of our own" which has a high bit rate, and it never even has to buffer..............
              UPDATE:
              [...] I get a weak signal base on the indicators.[...]
              MInixfreak wifi tweaks by far best experience ....never had issues but best wifi signal
                please check link for new version 6.9, I got error and can't download it
                  Yeah its not working
                    where is hello v6.9 download link
                      there is the link
                        can you post the full changelog of v6.9? so that we may also know what was added and changed.
                          When I remember everything I'll be glad to update it
                            BEELINK GT-KING PRO VERSION C92H/SA9H/SB9H/6B9H (916P0)
                            its out.
                            • trebor
                              trebor commented
                              Editing a comment
                              Is this post relevant to Spartan Rom:
                              Ease up....
                            Which Rom is for SA9HH?
                            Thank you
                              #SPARTAN V6.9 DDR
                              Device: GTKINGPRO WiFi6
                              DEVELOPER OPTIONS cannot be Disabled.
                              is it a bug or is it a New Feature for v6.9?
                              can we have an option to turn it on/off in the next update?
