[ROM] Spartan_ROM ATV S922X
Originally posted by Ced66 View PostYes can't boot on an sd with corelec but i can't also boot on an sd with V7.1 even if i plug power adapter pushing reset button...
At least V7 work well so its not a problem for now but i hope i Will be able to update after...
I tryied to Install v7.1 (DDR4) in B922 with SD card burn aplication, but´couln´t update. It Starts but it Hangs right from tha start.
Maybe only works with USB burning tool.
I will wait for a update. I has curious to try your new firmware i used an old one and was great, only move then to Superceleron because of the power on bug and stay on that until decide to try the new 921PO firmware from Beelink. But Beelink firmware are crap. Still full of bugs.
Originally posted by ki69 View PostI tryied to Install v7.1 (DDR4) in B922 with SD card burn aplication, but´couln´t update. It Starts but it Hangs right from tha start.
Originally posted by minixfreak View Post
i only make firmware ment for usb burning tool
For now i will try Slimbox, but i will keep an eye in your Work. Tks for suporting GT King ( an in my case B922). Regards
Thank you, thank you thank you. Marvellous and so useful rom. I tried any other roms but they arent successful like this rom.Everything is ok. and full working.
There is 2 problem i tested about rom.
Please add to the next rom these ,two issuies.
1- Microphone doesn't work at google asistant.
2- Android security patch is out of date : at 2018 . waiting for your updated patches.
Thank you minixfreak one more time. I pray for you.
Originally posted by Kyo View PostHi, I just installed this ROM, 7.1, DDR, on a GT KING PRO, with SN SB9X, and after the bootlogo it just stays blank, a black screen. If I press the power button, the power menu shows up, but that's all.
Any idea why? Thanks!
There are currently 2021 users online. 1 members and 2020 guests.
