[ROM] [S905X] Android TV Custom Rom 7.1.2 Universal (Most S905X based devices) (MXQ Pro 4K) 1/8GB
    Download v7.4 (24/Oct/2020)
    Download: https://bit.ly/aidanscustrom
    This is my version 7 Rom I use this as a daily driver and it is stable and Lag free
    Works well on 1GB Ram boxes
    Disney+ sound now works in v7.2 (Tested in v1.9.1)
    Improvements Made
    NO LAG!
    No longer based on atvXperience
    User Interface renders at full 1080p
    Fixed bug where remote power button would turn box off/standby but not wake it up again
    Added Miracast (scren mirroring)
    Removed Chromecast and other bloat (wont work in uncertified devices and would fill storage in 24 hours)
    New bootlogo and boot animation (No longer will bootanimation appear frozen during 1st boot)
    Bluetooth disabled (I can re add bluetooth functonality if someone needs it)
    Misc tweaks & adjustments
    New Update available
    Improvements [V7.4] (24/Oct/2020)
    PRE ROOTED! (Root switch does not work, Always ON)
    Disney+ now has working sound (v7.2 but worth mentioning again)
    All preinstalled apps can be Un installed (exept system apps)
    Samba MSWindows File Server [NAS] (Usb HDD, SD, Internal)
    Google Documents UI added (fixes bugs in some apps opening files)
    Stock Downloads File Explorer Added (Related to documentsUI)
    Google Assistant Text Search Navigation Bug
    Phone Settings crash fixed
    Wi-Fi Tethering now works (Ethernet to Wi-Fi)
    Changed Mouse cursor
    Certificate installer fixed
    GlobalKeyInterceptor added
    OneTimeInitaliser added
    GooglePartnerSetup added
    Updated Backdrop (no longer claims chromecast built in)
    Alternative Screensaver Included (Can uninstall)
    Reboot to recovery option in all apps section
    More visual tweaks
    More Performance tweaks
    Im very happy with how this turned out, please install and let me know if it works for you have any suggestion
    Tested on
    MXQ Pro 4K (1/8GB P212)
    Many More Devices (95% of s905x)
    Install using amlogic burn tool
    Download Burn Tool: https://bit.ly/aidanscustrom
    More Details On the Website & XDA
    aidanmacgregor
    Senior Member
    Looks nice and clean. You should add (MXQ Pro 4K) to your Title, there is hundreds of people with that device "1gb/8gb" always asking for ROMs.
      Thanks, have updated it now
        NEW VERSION 7,
        https://forum.xda-developers.com/and...7-1-2-t4104869
          Great ROM (version 7)! I put it on my X9. I have a problem with Netflix (version 7+ apk) - keep getting error where it can not connect to servers (but Netflix diagnostics indicate that it connects just fine.) Any suggestions / solutions?
            I use ROM from here, it works perfectly on my T95x S905x 2/16
            https://youtu.be/KZiLtY3p-cI
            Klik gambar untuk versi yang lebih besar Nama: 2020-06-09_13-09-41.jpg Diperkirakan: 0 Ukuran: 110,7 KB ID: 807629
            Klik gambar untuk versi yang lebih besar Nama: IMG_20200425_155119.jpg Dilihat: 0 Ukuran: 9,9 KB ID: 807631Klik gambar untuk versi yang lebih besar Nama: IMG_20200425_153414.jpg Dilihat: 0 Ukuran: 10.7 KB ID: 807632
              i have used that ROM, it works OK on my 2GB device but it come with problems that i have fixed in my ROM, also it is a horrible Laggy mess on my 1GB box and it will crash the box 5 mins after boot
              And this is not the place for recommendations THIS IS A ROM LISTING NOT A "RECOMMEND ROMS" or a "HELP BRICKED"post
              START YOUR OWN THREAD
              aidanmacgregor
              Senior Member
                Hi, Netflix on Android TV Requires Widevine LEVEL 1 certifacation, this is somthing that no custom rom can add as it requires certification from google, The mobile versions of these apps MAY work but will probably need a mouse to navigate
                  Thanks. Got the mobile version to work. Little inconvenience when ROM works so well. Great Job,once again.
                    Yhea ugly but effective workaround
                      unfortunately, brick my coowell v5 died for good after I installed the bootloader rewrite.
                        Aww that's bad news, you know how to recover using nand short method and another rom?
                          Hi!
                          I'm new here and just flashed my A95X box with your promising firmware but I need to add the remote mod to have it work and cant find a way to access TWRP. When I power on with the toothstick method it will boot normaly to Android...
                          Any tips/idea?
                          Thx
                          kLo
                            Oh and BTW, thanx to aidan for the great work!!
                              Thanks is it the nextbox remote.zip remote patch you need? im not too sure if the toothpick method wont work (i had to replace the recovery to get mine to work but i have also replaced uboot, bootloader & ddr files and i cant remember wich one specifically fixed it for me) i could include the remote files in a specific build for your box
