[ROM] [S905X] Android TV Custom Rom 7.1.2 Universal (Most S905X based devices) (MXQ Pro 4K) 1/8GB
Originally posted by thecook View Post
Can you say what was necessary to enable Miracast? I have a different device (X96S) and want to add it there (or some kind of other working mirroring).
Regarding chromecast, you mean that it is is impossible to use Chromecast on any non certified device? I already tried installing "Chromecast built in" app in my device but it didn't work.
New Update available
Improvements [V7.3] (06/10/2020)
Download: https://www.youtube.com/watch?v=0uci6Rl70t4
PRE ROOTED! (Root switch does not work, Always ON)
Disney+ now has working sound (v7.2 but worth mentioning again)
All preinstalled apps can be Un installed (exept system apps)
Samba MSWindows File Server [NAS] (Usb HDD, SD, Internal)
Google Documents UI added (fixes bugs in some apps opening files)
Stock Downloads File Explorer Added (Related to documentsUI)
Google Assistant Text Search Navigation Bug
Phone Settings crash fixed
Wi-Fi Tethering now works (Ethernet to Wi-Fi)
Changed Mouse cursor
Certificate installer fixed
GlobalKeyInterceptor added
OneTimeInitaliser added
GooglePartnerSetup added
Updated Backdrop (no longer claims chromecast built in)
Alternative Screensaver Included (Can uninstall)
Reboot to recovery option in all apps section
More visual tweaks
More Performance tweaks
Hi Aidan, can I install it on Mecool M8S Pro+; it's a s905x SOC p212 board with Mali 450 GPU (also i think I rooted the box last time i flashed a rom in). The box runs Android 7.1.2 buildid -userdebug 7.1.2/NHG47L/20180806.102424.V0213. I have TWRP 3.2.3 in the box presently which runs fine and box brings up recovery TWRP screens (once reset button is shorted). It's a 2/16 board with a sci s9082c wifi chip. TWRP 3.2.3 only lets me flash a .zip (or OTA package). It asks for target partition if .img filetype is selected but the options shown are only boot, recovery, and logo partitions. Apparently TWRP won't flash to data or system partitions. Can you please make an OTA or zip of this firmware to port from the above version.Last edited by quasims; 11 October 2020, 15:59.
Originally posted by quasims View PostHi Aidan, can I install it on Mecool M8S Pro+; it's a s905x SOC p212 board with Mali 450 GPU (also i think I rooted the box last time i flashed a rom in). The box runs Android 7.1.2 buildid -userdebug 7.1.2/NHG47L/20180806.102424.V0213. I have TWRP 3.2.3 in the box presently which runs fine and box brings up recovery TWRP screens (once reset button is shorted). It's a 2/16 board with a sci s9082c wifi chip. TWRP 3.2.3 only lets me flash a .zip (or OTA package). It asks for target partition if .img filetype is selected but the options shown are only boot, recovery, and logo partitions. Apparently TWRP won't flash to data or system partitions. Can you please make an OTA or zip of this firmware to port from the above version.
aidanmacgregor Any idea why boot up stuck at this point looking for /boot/optee_armtz.ko?? I attached the log.
I download v7.4 and only the MXQ version would complete 100% using USB Burning Tool. The other one Nexbox and Universal would fail to flash at the very end when it fail to match the hash for system partition. Not sure why this happens.
I attached the log of the bootup.
UPDATE:
I was in going in the right direction. I needed an older version that was also MXQ type.
It finally completed and booted 100% using atvXperience_S905X_mxqpro.img.
Thank youAttached FilesLast edited by hieppo; 03 March 2021, 01:45.
Originally posted by hieppo View Postaidanmacgregor Any idea why boot up stuck at this point looking for /boot/optee_armtz.ko?? I attached the log.
UPDATE:
Thank you
There are currently 1369 users online. 2 members and 1367 guests.
