Pipo M7 Pro RileyROM 1.8
    This ROM is based on an official Pipo ROM released by tech support to a user dated 10-21-2013.
    I've taken a turn in philosophy on this one. This time I have taken great pains to debloat absolutely as much as possible from the system apps to provide a clean, fast ROM.
    This ROM is:
    Rooted with SuperSU
    Debloated
    Init.d Support added
    Busybox commands added
    Google Play Store Fixes
    Streamlined Ext4 File System
    English Default
    Chinese Keyboard left in - by request from Chinese users
    Multi-User Support added
    Very few build.prop tweaks added (to improve streaming)
    CWM Recovery as an option
    Default user data space for apps is 4gb (with 8 and 12gb as an option)
    I've tested Netflix on this ROM and it works.
    I have not encountered any freezes as of yet while testing.
    Boot animation art provided by Tattman65
    Reboot App by Petrus
    Flash Tool by Finless
    First Time User's Guide by Pr0xZen
    Download
    Enjoy!!!!!!
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com
    Donate!!!
    Randy
    Hello mate, that was fast!
    Any opinion if GPS working with this version? I tested with 1.7a but couldnt make it work.
    Ty in advance and keep it coming, we really appreciate it!
      benchmark score 19652
        That's awesome! Any changes from 1.7?
        Proud M7Pro owner and Freaktab fan
          havent notice anything yet,but it is very fast,im using antutu cpu master,and changed my profile to ondemand,Click image for larger version
ID:	430988Click image for larger version
            i think the H265 support is not in this rom,tried instagram,the video is not showing,it only plays sound
              can you check whether 3g and deep sleep work?
              Thank you
              Giovanni
                Well, it seems h.265 support was removed for some reason. Anyway, there is no much use of it right now. And original ROM image is 20 MB bigger than #414 with h.265 support. Just wonder, what is there.
                And 3G modem is off by default. So tablet sleeps well until 3G is turned on. After that reboot is needed to get deep sleep working again.
                Update
                The 20 MB difference is just one game. However, found that libhevcdec.so is missing in update#6 and Riley ROM 1.8. This one is for H.265 support, but only one or not don't know yet. And also 18 lib files are different including related to camera, light and other sensors
                  Hi, miss the 4.2.2 stock clock.
                  Anyone can upload it?
                    bpsim, here you are, not sure if it's the same as stock, taken from the latest ROM
                    DeskClock.apk
                      [ATTACH]3659[/ATTACH]
                      I think it is the same as stock.
                      Direct install not working, needed manually copy paste to system app and set permission.
                        of course, this is system app
                          I think there is bug on the settings,sometimes when you are changing your options,for example the timeout of the display,it doesn't change,it reverts to its settings,or the multi window,sometimes when you are switching it,it doesn't work.I don't know if others experience it,
                          Last edited by dianne.abena; 24 October 2013, 02:51. Reason: fixed,just rebooted it
                            Re: Pipo M7 Pro RileyROM 1.8
                            I've been trying to recreate that problem but so far mine isn't doing that.
                            Sent from my M7pro using Tapatalk
                            Randy
                              fixed my problem,i just did a reboot
