[ROM] "Generic" SC ATV v1.0 USER/USERDEBUG - S912 Android 9 - Multi-Wifi BCMBT/QCABT
Hello, I've used the ATV version so far[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard + Ultimate)
MULTI_Z6BASED_ATV10.7.img where both WIFI and Bluetooth work for me. I have box Beelink GT1 Ultimate with fake Ram 2GB. I installed the version
SC-S912_Android_Pie_UserDebug_QCABT_v1.0-20200720-DDR3 & DDR4-FIX.7z,
which was installed, but it was not possible to connect Wifi right at startup, so I used LAN RJ45, which works,
but wifi and bluetooth does not work this. to fix? I know that I tested the version [ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4) where everything worked.
Thanks for the answer.
Originally posted by quicksilvercz View PostHello, I've used the ATV version so far[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard + Ultimate)
Do I need to check the "erase bootloader"?
I installed via USB_Burning_Tool via RJ45 everything works well, but I want to have it via WIFI and play bluetooth audio headphones.
If you could upload some data there via USB RAR (ZIP) Wifi and Bluetooth FIX it would be good.
Https://mega.nz/folder/YRR2mIBI#yr1hReLX08NyDgSu1Rrneg // MULTI_Z6BASED_ATV10.7.img works well on my box if you could
find out what wifi and bluetooth is there and make it an installation. Thanks a lot
I'll leave nothing to the checkboxes and sell the installation via the USB_Burning_Tool 2.2.0 application via USB.
Pls add. wifi AP6255 Beelink GT1 Ultimate S/N AX12, and Bluetooth FiX...
Dear Developer (Superceleron),
I had installed ATV9 beta3 firmware by hungphutho/DaivietPda on my H96 Pro+ box 3G DDR4/32 and then decided to give a try to your SC-S912_Android_Pie_User_QCABT_v1.0-20200718-DDR3&DDR4.img firmware where you mentioned that compiled with rls keys, because I want to run my paid iptv service.
I have checked the "About" information and Build is PPR1.180610.011.20200718 test-keys, Kernel version is 4.9.113 #1 Sat Jul 18 19:48:52 WEST 2020, Model is hertz.
Is this normal? Also AIDA64 app shows only 2 GB Ram instead of 3GB.
Thanks in advance for your time !!!!Last edited by sohoceasars; 27 September 2020, 19:50.
Hello, thank you for the rom, can i try to install with SD card with this method AMLOGIC BURN CARD MAKER : https://chinagadgetsreviews.com/down...er-v2-0-2.html ?
Originally posted by thanx View PostHi
thanks for the ROM
any chance to get the init.d?
but i really cant tell since there are to many H96 pro+ hw revisions out there...
Originally posted by borefdehut View PostHello, thank you for the rom, can i try to install with SD card with this method AMLOGIC BURN CARD MAKER : https://chinagadgetsreviews.com/down...er-v2-0-2.html ?
Ok, so I tried it on my GT1 (2/32, DDR3) using the BCMBT (AP6255 or whatever), and here is how it went:
- Boots up (yes it does, lol)
- WiFi works on 5Ghz and 2.4Ghz
- Ethernet 1Gbps
- USB drives are recognized (did not test the speed, I dont have fast ones anyways)
- 32GB of storage recognized
- Remote Controller (the full one with numberpad, not the one with keyboard tho) works (for the most part)
Issues:
- Pressing the power button shuts down the whole device instead of sleep
- CEC have issues: I can control it, but power off/on does not work, if I turn off the TV, the LED is still on and when turning the TV on, I have to press the box's RC power button to wake it
- 4K (at any fps) is choppy (I guess I expected that?)
- (I did not test any app that require DRM, but I dont expect it to work with full resolution)
- that's all for now.
What I would really want to see is Chromecast support! That would be really awesome! Thanks superceleron for this ROM!
Originally posted by ppromo47 View PostThank you very much for this
My box is TX92 3/32 LPRAM and it works
Bugs :- Initial setup using phone fails, it goes back to start
- Userdebug doesnt have TWRP, i had to install it,
- Reboot recovery command in terminal doesnt boot to recovery, I have to use reset pin every time
- Magisk I was able to install via recovery, but I lost root access when I rebooted, magisk apps is not able to detect patch
- Android remote on my phone works with WIFI but doesn't work with Bluetooth, it use to work with ROM released by HighwayStar (Bluetooth (QCABT) works I was able to pair it with my phone)
There are currently 1742 users online. 0 members and 1742 guests.
