[ROM] "Generic" SC ATV v1.0 USER/USERDEBUG - S912 Android 9 - Multi-Wifi BCMBT/QCABT
I've installed this rom on my H96 pro + 3/32.
The rom is ok, i've some problem with remote...but there is a way to make a PS4 controller working in bluetooth?
If i connect my controller with cable it works ok, but if i connect it via bluetooth, the controller is connected but nothing move on the screen.....
I've also tried to replace the /system/usr/keylayout with a set taken from a previous rom, where my PS4 controller was working in bluetooth.
If someone has a solution to make a controller working in bluetooth, please let me know....
GT1 standard here must be 10 years old (q201 9377) the QCABT user version works great wifi and bt are strong Ive rooted it with magisk using a video thats on ut for another pie image everything seems to be working great even 4k hd
one thing ive noticed flashing different roms is the pie images seem to effect my ability to flash images in a good way I dont have to use a pin any more on some images i can power on and plug usb in fast and i get a successful connection and on yours i get a connection by just pluging in the usb first and once connected put in the power its great if i go back to android 7 roms i have to use the pin reset again
Please build this rom for LPDDR3
i cant make it from img for ddr4& ddr3 to LPDDR3
thank somuch
unpack level 1 is all you can do with this tool on android 9 so do it when done click advanced tab and click open working folder
open level 1 dir and paste in your 4 new files and overwrite when asked, Back to the tool and click packaging tab
click repack to aml upgrade package choose a name for your patched img and save Burn, in the usual way
Originally posted by wadger View Post
it very easy you only need level 1 extraction, so on windows google AMLogicTools_V7.1.0
i done
For Minix IR remote
/vendor/etc/remote2.tab
Code:custom_name = amlogic-remote-2 custom_code = 0xfe01 release_delay = 100 key_begin 0x47 105 #DPAD_LEFT 0x15 106 #DPAD_RIGHT 0x46 103 #DPAD_UP 0x16 108 #DPAD_DOWN 0x55 97 #ENTER 0x40 1 #BACK 0x04 125 #MENU 0x14 115 #VOLUME_UP 0x10 114 #VOLUME_DOWN 0x0d 102 #HOME 0x18 116 #POWER WAKE 0x12 243 #SETTING_MENU 0x20 131 #ZOOM_OUT 0x21 130 #ZOOM_IN 0x22 217 #SEARCH 0x23 113 #VOLUME_MUTE 0x24 120 #MEDIA_FAST_FORWARD 0x25 121 #MEDIA_REWIND 0x26 119 #MEDIA_PLAY_PAUSE 0x27 128 #MEDIA_STOP 0x28 123 #MEDIA_NEXT 0x29 122 #MEDIA_PREVIOUS 0x30 2 #1 0x31 3 #2 0x32 4 #3 0x33 5 #4 0x34 6 #5 0x35 7 #6 0x36 8 #7 0x37 9 #8 0x38 10 #9 0x39 11 #0 0x41 14 #DEL 0x3a 52 #dot 0x3b 28 #ENTER 0x3c 359 #RECORD 0x3d 94 #prog1 0x3e 95 #prog2 0x3f 514 #prog3 0x41 515 #prog4 0x42 177 #pageup 0x43 178 #pagedown 0x44 358 #info 0x45 362 #guide 0x48 402 #CH+ 0x49 403 #CH- key_end
Does anybody have an idea about how to get the remote.conf information from the Superceleron V4 Adroid 7.1 to move it to the SC-S912_Android_Pie_UserDebug_BCMBT_v1.0-20200720-DDR3&DDR4 in the Alfawise H96 pro + box?
I know it is been repeated but the keys are all out of mapping.
I tried messing up with /vendor/etc/remote2.tab
And a bit of the instructions found at https://forum.xda-developers.com/t/c...quire.3548871/
But all I managed was to make the remote totally unresponsive which was something that the post on xda mentioned as a possibility.
It is doing up my head because if I managed to totally break it it means that there is a chance that the remote can be remapped.
I have three of these boxes but I am only trying this firmware on one. I tried Aidan's firmware but it runs very buggy. Other than that one the Super celeron are the only ones that run on these Alfawise 3/32Gb green PCB boxes. And to get here I had to mask rom to unbrick it from a forced update with the wrong firmware.
Originally posted by superceleron View Post- H96 Pro, 1/2/3gb DDR3 - issues none (well maybe IR remote)
- H96 Pro, 1/2/3gb LPDDR3 (use LPDDR3 Uboot) - issues none (well maybe IR remote)
- Beelink GT1, DDR3 - issues none (well maybe IR remote)
- Mecool M8S Pro L, LPDDR3 (use LPDDR3 Uboot and then flash the 100mbits eth zip fix) - issues you will lose L1 but you can't use it for anything anyway and IR remote.
- Tanix S912 (cant remember the version) 2/4gb DDR4 - issues none (well maybe remote)
- Minix Neo U9-H, DDR3 - issues, you will lose the full size usb ports, small mini usb port still works as a normal usb and IR remote.
thank somuch
I also put this ATV rom ( SC-S912_Android_Pie_UserDebug_QCABT_v1.0-20200720-DDR3&DDR4-FIX.7z ) on my H96PRO Stick ( S912 2/16gb DD3 ) and it works great, only I have wifi and bluetooth chipset RTL 8723bs, so please, if possible, some patch to unlock bluetooth Thanks a lot !
I tried other versions too, but unfortunately bluetooth doesn't work on them either
Superceleron Is there any hope to patch even though you wrote that you will not work with this version anymore due to lack of time and its age romLast edited by Maksa; 17 February 2024, 20:04.
Originally posted by Maksa View PostI also put this ATV rom ( SC-S912_Android_Pie_UserDebug_QCABT_v1.0-20200720-DDR3&DDR4-FIX.7z ) on my H96PRO Stick ( S912 2/16gb DD3 ) and it works great, only I have wifi and bluetooth chipset RTL 8723bs, so please, if possible, some patch to unlock bluetooth Thanks a lot !
There are currently 2052 users online. 0 members and 2052 guests.
