[ROM] "Generic" SC ATV v1.0 USER/USERDEBUG - S912 Android 9 - Multi-Wifi BCMBT/QCABT
Originally posted by ppromo47 View Post
Your theory is incorrect, because I m able to connect remote over WIFI and pair it, and this feature (Setup using my phone) has nothing to with Bluetooth so its something else. but never mind its not important feature, as its only one time usage.
Or you talking about setup pair your account? where you get a code to set in the phone?
Just trying to understand, because if its the atv remote app then only wifi is working because i have bt disabled by default.
If its the setup pair your account, i removed the step where you can login using your phone because its old, this setup wizard is from android 8, the newer ones from 9>up is bound at sdk compile time to that build.
1- Yeah, thats one time usage feature, its fine
2-Thats fine, I have managed to create one
3-Tried with both User and Debug. same issue
4-Thats fine, its might be something related to encryption, I couldn't get it working so moved back to higwaystar
5-Thats a bug for sure,I did restart bluetooth just to be sure
the 5 im really not sure what you mean for real :/ i do not have any issues with bt on any of the bt chips builds.Last edited by superceleron; 22 July 2020, 17:05.
To anyone who can't use the remote the ps3, ps4 and xbox controller are working.
You can use them if you want to input the wifi password to skip the initial setup and then install a android remote app to use your cellphone as a remote controller.
Btw superceleron the u-boot from bumerc is working fine for now except for an error at 2% when flashing it (maybe caused by the repack i'm using on windows "Customization Tool"), i will test it more and let you know.
Originally posted by Massimo1993 View PostTo anyone who can't use the remote the ps3, ps4 and xbox controller are working.
Goodi made my DDR3/DDR4 uboots 912 for both so some boxes with "cheap" ram chips might have some issues with it.
For LPDDR3 i set it in the middle 744, so it should work on pretty much "all" boxes out there.
But glad is working ok for you the uboot he did
superceleron Can you guide me, how to enable Navigation, Status bar and white settings?
I suspect you don't care and that's why its not in your ROM, however I still prefer it, any help much appreciated, thank you.
By the way your ROM is 32 bit :|
EDIT : I found a way to get the white settings back.extracted the Settings, Droid Settings and SystemUI from DavietPDA's Rom and then replaced it with root explorer in priv-app folder, set the permissions 644 (files) and 755(folders) , reboot...DoneLast edited by ppromo47; 25 July 2020, 17:42.
Originally posted by ppromo47 View Postsuperceleron Can you guide me, how to enable Navigation, Status bar and white settings?
So i removed a few stuff.
If you wait a few days im doing a "normal" build with all that you want, just wont be ATV.
That includes settings.apk fixed since the one from khadas sdk is broken in some places and has some missing stuff.
That would be sweet! Trying out Slimbox 5.1 AOSP right now...no play store...but everyone's work towards Android 9 is spectacular!
I may sound needy, but, a LPDDR3 build would be nice. Bricked my box (again!) trying Customization Tool and your LPDDR files.
I think that makes about 7out 7 fails with the tool in the past 12+ months.
Sorry im cant help you, i make my ATV roms to be like real ATV.
thanks
al ok but remote not work
can u add the remote from atvxperience (all remote working)
I tried your rom and it worked very good for the tx9s box
I had already a backup from my old rom and I tried to restore it through twrp recovery but it failed ,now the box stuck at boot logo,I can open the stock recovery or even boot the twrp from the sd card
but I can’t install other firmware with the sd card method,the green android icon appears for half a sec and disappears and it goes back to the boot screen
also I am not able to connect it to usb burning tools like before and I tried the short pin method in 2 different Locations that I found online without any luck
is the any way to flash my old img firmware on it or even fix yours atv 9 firmware?
thank you
There are currently 2433 users online. 1 members and 2432 guests.
