[ROM] Mod: HK1 X3 / H96 max X3 / VONTAR X3 / Transpeed X3 Air / Bqeel Y8 Max (Amlogic S905X3)
Originally posted by n0v1ce View Post@str0g0 will detects su file regardless root is activated or not, so need to remove su binary completely
Originally posted by n0v1ce View Postoops my bad, i was confused yours with slimbox, gonna try yours however mega's quota is exceeded, hv to wait the cooling period is over
#update: tried, su file is detected
#update2: after uninstall magisk, issue resolved
Anyway if what you have done already is OK for you, that's all that matters. But if you use correctly the magisk app you may have a box at the same time "rooted" and "unrooted".
Originally posted by ath156 View Post
As I already told you there is an option to "hide" the magisk from certain applications (there is a special menu for this inside magisk).There is even the option to give a completely different name to magisk (whatever you like) so it will not be discovered by some applications.
can't use magisk's hide feature as the app detects magisk's interception and won't allow to proceed, so hv to uninstall magisk & disabled magisk manager
In case this is not successfull there is even an option to completely rename magisk (giving it another arbitrary name).
I am almost sure that following this or another way you can use the desired application and magisk at the same time. The result would be to have at the same time a rooted & unrooted system.
If you are eager to try all these please report your experience.
Magisk is preinstalled and in most cases the "hide" feature is enough. For some services you may have to use the additional option to completely hide magisk manager by giving the whole package an arbitrary name (Magisk Manager-Settings-Hide magisk manager). Of course if this is not enough for you, you can also unistall it.
Please after the 1st boot update the app from 20.3 to 20.4 (latest).
ath156
I am waiting form my new HK1 - it´s the one in the attached link
So your rom is working on this box? i don´t need to look for green and blue boards or care of installed stock rom (u219 etc.)???
Concerning the launcher:
I bought and use the Square Home Luncher in some diferent boxes and tablets. (incl. the key). My actual version is 2.1.13 from Play Store. Which version you have integrated in your rom? you write Square Home 3 ??
If i install your rom, can i use my paid version with the key app then? i got the experience from my Beelink GT King that i had to uninstall first the SH Launcher which came with the custom rom (Sasvlad) and then install my bought rom.As found the firmware for HK1 BOX possibly works with also for VONTAR X3 but as stated is primary for the HK1 BOX dated u219.HK1_BOX_1000M_9.0.2019.12.28.11.34 use it at your own risk hope it helps someone. tv-boks-hk1-box-s905x3-obzor-3.jpg All Available Roms,tweaks,tips can be found here https://4pda.ru/forum/index.php?showt
- You are absolutely right to get confused with GREEN & BLUE boards, as it was my mistake to not clarify that I was refering ONLY to H96 max X3 (which has a new version with BLUE board). Even there it seems to be no problem, that's why I deleted the relevant Notes.
- As the Square Home Launcher and the key you own I really don't know. If you have any problem you can easily delete my version and install yours. As far as the name is concerned you are also right as sometimes it is referred as Square Home 2 and sometimes as 3.
For anybody that would like to try other roms (mine or other custom roms) it is a good practice to first make a Backup of their partitions with a NOT permanent TWRP. It is easily made as I say here:
A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB https://image3.geekbuying.com/content_pic/201910/A95X-F3-Amlogic-S905x3-8K-Video-Decode-Android-9-0-TV-Box-4GB-32GB-20191010151934882.jpg Highlights as Found Amlogic S905X3 applies quad-core Cortex-A55 processors, which is described as an
You have to backup at least Boot, System, Vendor and your Data partitions.
- YES. My rom works perfectly for HK1 BOX and the link you attached. A friend of mine installed it at exactly such a box and everything functions perfectly. It is also suitable for HK1 X3 (the circural one) like this https://www.banggood.com/HK1-X3-Amlo...1&rmmds=search. So for both othese HK1 S905X3 versions !!!
There are currently 1483 users online. 0 members and 1483 guests.
