[ROM] Mod: HK1 X3 / H96 max X3 / VONTAR X3 / Transpeed X3 Air / Bqeel Y8 Max (Amlogic S905X3)
Originally posted by ath156 View Post
- As the Square Home Launcher and the key you own I really don't know. If you have any problem you can easily delete my version and install yours. As far as the name is concerned you are also right as sometimes it is referred as Square Home 2 and sometimes as 3.
Originally posted by tombraga View Post
As i said, i use actually the version is 2.1.13 from Play Store. Could you look to your version which is included in the rom? For example with SD Maid in app control? thanks
Some other preinstalled apps are also automatically updated.
OK this is very easy to find. The version that first installs by my rom is 2.0.2(20002), but after 1st boot and letting Play Store find any updates, it is updated to 2.1.13(20113). That version is what I actually have now (after the update from playstore).
Do you use also SD Maid Pro in your devices? i use it often to keep all clean and organized. But this app i can also install after afterwards.
ath156 concerning heating of the HK1
In the anexed YT review there is the following comment by a user about heating:
"...Not a professional cursory review. This box heats up like an iron when watching HD video. The inside of the radiator is very small. You cannot use without additional cooling! The processor reduces the frequency and the box turns into a crappy product from China!..."
do you think with your rom this problem perhaps reduce? Or could it be worse?
Even if you don´t have the same box, perhaps you can give some idea.
Or any other user, which bought the HK1, is there any diference about getting hot, comparing the stock and custom rom of ath156 ?Unboxing and Review of the HK1 Full Android TV Box - including specs, features, real time 4K streaming tests, benchmark rankings and more! Subscribe to the c...
Please have a look here about this subject https://forum.freaktab.com/forum/tv-...e18#post813789
Please note that your USB ports STILL HAVE POWER even when you turn off your Box (you must take care about it so not to spin 24/24 & 7/7 - at the above link are some options).
I think it's a good practice to use a cooler fan for every TV box you may have. That's what I do for all my 3 boxes (Beelink GT1 2/16, H96 max X2 & H96 max X3). I did all of them by myself (DIY) using very old fans from Tower Pcs.
But i wanted to know, if you think there is a diference (concerning heating) between the stock rom and you rom (which is based on the russian version)?
Thanks and yes, i also use this cheap external usb-coolers in nearly all my boxes (7 diferent boxes...)
There are currently 2148 users online. 0 members and 2148 guests.
