[ROM] Mod: HK1 X3 / H96 max X3 / VONTAR X3 / Transpeed X3 Air / Bqeel Y8 Max (Amlogic S905X3)
Originally posted by soldiaz View PostSounds good, so the ugoos fw suits to his one? I will have closer look on the chipsets (WIFI, LAN, DDR) and provide information
**Note1: This must be suitable for all TVboxes of this "family" with Gigabit Lan. It is not suitable for HK1 Box with 100MB Lan !! It is not suitable also for H96 max X3 with Blue Board and wifi module IT6334 (everything will be fine except wifi).
**Note2: Since you have 1.000MB Lan there should not be any problem with this rom (probably you will not get a brick), but you may have problem with wifi (if you have a wifi module similar to IT6334)
**Note3: Your TVBox must be a "copy" of my H96 max X3 where I use 0.4.2 AOSP, but my board is Green (wifi problems are with some of H96 with Blue Board).
Whatever you do, you are doing it at your own risk. Good Luck.
Originally posted by ath156 View Post
This is the stock firmware. If you buy this TVbox just say it and I will give you some more links. Also state if you prefer AOSP or ATV.
HK1 X3 Android 9.0 4+64GB TV Box Amlogic S905X3 2.4G+5G WiFi 4K Set Top
as seen here (scroll down on site): https://www.****.de/itm/115333681292?var=415383532172
It is the same Box like soldiaz
However, I have 4/64 GB and 100MB Ethernet.
I guess I am going for an ATV ROM, since I am coming from a Fire-TV Stick and am used to it. I basically only use Kodi to watch TV and stream Videos from my Network-Harddisk.
So I guess I have no need for "Open Source" for now.
I created another thread for the round one:
Decided to create own thread since I dont know wether is same like rectangle one. Stock Firmware supposed to be these: 32GB ROM version STOCK initial HK1_X3_S905X3_2019-11-23.zip HK1_X3_S905X3_1000M_U212_9.0.2019.11.23.18.29.img https://drive.google.com/u/0/uc?id=18yFXnEv-awubFjS3fuEH2g2DJ9mx6E8C&export=download
I linked the 64GB unit as well, but it is for Gigabit LAN
There are currently 2716 users online. 2 members and 2714 guests.
