[ROM] Mod: HK1 X3 / H96 max X3 / VONTAR X3 / Transpeed X3 Air / Bqeel Y8 Max (Amlogic S905X3)
Originally posted by bishopx26 View Post
One more question. I hVe x96 max and hdmi doesnt sbow picture. It only works with av cables. I tried new hdmi , new tv still same. Is this due to processor failure?
So if you happen to have a an x96 max with no protection at its HDMI port and especially if you did a "hot-plugging" (connecting the HDMI cable while both TV and x96 are ON), then most probably you have "burnt" your HDMI port. Of course this may happen due to other reasons also. And YES if you "burnt" the HDMI port this also may have to do with the processor.
So as to be "Safe than Sorry" never do "hot-plugging/hot swapping" of the HDMI cable, even if your TVbox has protection at this port
Originally posted by ath156 View Post
Some TVboxes have protection at their HDMI port, but others no protection at all !! You can find this by just inspecting the TVbox's motherboard.
If you are using Coreelec on an sd card (dual boot system Android-Coreelec) I remind you how you can have temperature and time in the front screen:https://forum.freaktab.com/forum/tv-...334#post824334
Just a small tip: If you want to have permanently the temperature at the front screen, just choose both values to be 30sec. After the initial 30sec the small screen will have the temperature indication permanently upon it.
What is the process of reverting to the default rom. I have the original files from H96 Max website https://www.h96tvbox.com/content/6-Firmware-upgrade
I want to run a test then go back to your rom.
Originally posted by get2abbey View PostWhat is the process of reverting to the default rom. I have the original files from H96 Max website https://www.h96tvbox.com/content/6-Firmware-upgrade
Originally posted by Based_Skid View Post
Well there is a tool bundled with the files that you can use and what you would do is hold the reset button while connecting it to USB but this method is really not solid and if you have a SD card you can actually prepare a burn card image I know the tools are around here somewhere but I can upload them for you if you would like
Originally posted by get2abbey View PostThanks, pls do upload here for me
[ROM] Mod: HK1 X3 / H96 max X3 / VONTAR X3 / Transpeed X3 Air / Bqeel Y8 Max (Amlogic S905X3) This mod is based on the Malay mod v1.2 . You can download the Malay mod (starts in Russian) from here : https://yadi.sk/d/GWW_dL7anKvorA The Malay mod is based on the original for HK1 X3 u219.HK1_BOX_1000M_9.0.2020.01.13.12.35
You can install any firmware you like using these methods (better use USB Burning Tool).
So instructions at the 1st page of this thread under the section "How to install" (either by USB Burtning Tool or by Burn Card Maker) are not enough for you ?
There are currently 2394 users online. 0 members and 2394 guests.
