[ROM] Mod: HK1 X3 / H96 max X3 / VONTAR X3 / Transpeed X3 Air / Bqeel Y8 Max (Amlogic S905X3)
Finally......you say
More like be thankful is has
It was nearly gone for good,
Due to worldly matters etc, not as easy you may think, lots of work goes on in the background to keep it running.
If FREAKTAB has be good to you or anyone who reads this, small donations always handy to keep the bills away.
Anyway, glad to see it up and running again........... Don't know what I would do without "seeing" the masked superhero again.,MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by get2abbey View Postath156 installed this Rom on my H96 Max X3 4gb RAM/128 GB storage, I must confess I am impressed. Everything works well except for the Bluetooth, bluetooth is not connecting to other devices. Unfortunately I did not do any back up before installing your Rom.
Any solution?
Originally posted by ath156 View Post
There must be no problem with Bluetooth (at least problems that I am aware of). Do you have a blue board or a green board? Do you have wifi?
I have I green board, Wifi is working perfectly… as I mentioned earlier EVERYTHING work well except bluetooth
Thanks for the prompt response.
I also have an H96 max X3 with Green board. I just connected my smartphone Xiaomi Note 4 with my H96 max X3 through Bluetooth. I transfered a file from my smartphone to my H96 and another file from H96 to my smartphone using BT. No problem with it. I don't know if you want BT for some other function e.g. BT headphones (I never used it for this purpose).
To enable BT there are at least 3 ways:
1. Settings-More Settings-BT-Search for BT devices there and enable BT
or
2. Drop down (with a mouse or airmouse) the notification panel (dragging from the top of the screen), expand the upper part of it, enable the BT icon.
or
3. Maybe the best option is to create a square in the Square Home Launcher "Press +" - "Shortcut" - "Quick Options".
From there you can easily enable/disable BT, find more options, see which devices are already connected or search for new ones.Last edited by ath156; 25 March 2021, 04:43.
I asked you about the color of the board because if you had one with Blue board and wifi chip IT6334 then you would have no wifi+BT unless you used the special custom rom for it.
To enable BT there are at least 2 ways:
or
Thanks again for the quick response. I wanted to connect ps4 controller to play games and a JBL speaker
Did you finally succeed in connecting the PS4 controller or the BT speaker? I don't have a PS4 controller to test, but I have a couple of BT speakers. When I find some time I will certainly test them. Also if you still are using this firmware see option (3) in my #250 post.
As I did a new clean install of my custom rom to H96 max X3, I prepared a file with instructions to help you update Magisk directly to latest version 22.0. Not everybody needs to do this update.
Please report if you have any problem with these instructions and the update.
I have another file with instructions of how to pass SafetyNet with magisk v.22.0 (I will sent it by PM to anybody intrested - but 1st they must have updated to v22.0).Last edited by ath156; 06 April 2021, 17:26.
There are currently 6662 users online. 0 members and 6662 guests.
