MECOOL Android TV Box KM6 Deluxe Edition Powered by Amlogic S905X4 AVI supported
dfinikis nope. I gave up, tried many things (replaced the HDMI cable, change sound settings both ony LG smart tv , the Box). Nothing happened same issue. So I subscribe a Plex share server which has all of the Apple Tv+ content... Also on my Xgimi DLP Android TV projector the app working with sound... (Android TV OS 9).. so I think this is KM6 sound codec issue or LG TV issue ( my TV is 6 yrs old). I just don't understand why working other users...
tonymhu , my tv is also a 6years old Samsung model, but as I said the same issue (no sound) occurs when I connect Bluetooth earbuds, so I think it is not related to the tv.
I use the latest Apple tv app version 4.1.
Let's hope that someone from the forum with Km6 that does not face this issue will have more ideas to propose us.
//dfinikis
@tonymhu, I managed to resolve the issue with AppleTV on KM6. You may find below the settings I used
AUDIO OUTPUT -->
DOLBY DRC mode = LINE
Accociate Audio = OFF
SOUND -->
System sounds = ON
Select formats = AUTO
I have also set HDMI sound format = PCM in my TV.
Before the issue is fixed, I have played a Dolby ATMOS sample - I have downloaded from this link and copied to KM6.
http://thedigitaltheater.wetransfer.com/downloads/0f0f4814744e10990bf66f9ed289ced820180318102235/0eb598
I tend to believe that the this Dolby ATMOS sample somehow helped the BOX to work properly.
//dfinikis
dfinikis thank u for sharing these infos. For me still the same no sound. I don't have option in my LG to set HDMI sound format. Its automatically changed, I saw when I push the info button on my TV controller and for AppleTV app is PCM. Also checked the video that you linked, and same bo sound the interesting thing my TV changing Dolby Digital the HDMI sound... So I gave up, I want to buy a new TV so I dont mind...
@tonymhu, this is exactly the issue. Km6 sends to your TV the sound in Dolby Digital format, that may not supported by your TV. The correct is to send in PCM format.
One last test, if you have time. Download "FX File explorer" from Google Play in your box, and then play the previous Dolby ATMOS sample with FX player (whcih is installed with FX file explorer).
I have seem cases that divverent movie player have different behavior - personally I played the sample with FX player. ..and voila, at last sound in Apple TV app.
//dfinikis
Did anyone could help me with Km6 deluxe firmware? I've updated to the 907102009001, but it's seem it's now running some apps so bad that i want to use another firmware, before the update, for example, Xbox gamepass App was running so good, but now it freezes when i try to play, can anyone send me another firmware?
Originally posted by kikko View PostBuenas noches. Necesito el firmware stock del km6 Deluxe para volver a flashearlo. Saben dónde puedo encontrarlo ??? Gracias
Originally posted by bergamesk View Posty guys what y think about the new KM7 ???
905Y4 ???
https://www.mecoolonline.com/collections/mecool-km7
Originally posted by Ty_Bower View Post
I have no problem with the SoC. I do take issue with the lack of optical audio output, which should be mandatory for any device at the heart of an AV system.
Of course most of these devices do not support those HD audio codecs.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
hello. i have a mecool km6 deluxe device
i have facing a serious problem . when i boot the device on , device date and time automatic goes to old date. i have tried network and manual settings but it Doesn’t work. then i factory reset the device. still it doesn’t work ?.
every time i had to manually setting date and time.
if i doesn’t set the time correctly then my internet doesn’t work anymore untill i set it correctly. thank u. i hope some give me a real fast solution
There are currently 2698 users online. 2 members and 2696 guests.
