MECOOL Android TV Box KM6 Deluxe Edition Powered by Amlogic S905X4 AVI supported
Ok, though I think the problems I found with launcherX is from keeping ATV launcher. All the instructions about using LauncherX, tell you to uninstall the stock launcher. I assume once rebooted, the lack of the stock ATV launcher won't cause issues. I did not find LauncherX as nice as others. Too busy with pages and what not for my taste. Simple and sweet is my motto.
That is a good question. When I played the test videos, it did NOT show 4k in the stats, however, it does list 4k and HDR, which contradicts each other. This is the only device that I have/had that did not show HD or 4k in the stats, but still showed the "emblems" of HDR, or HD, etc.
So, since I did not know what indication to believe, I did a comparison to the Nvidia Shield. Both devices connect to my Yamaha AVR then to my Visio HDR TV. I played the same video on both devices ( 3 different movies), and they looked identical, that is why I believe that this ATV Netflix is indeed playing in 4k. But, that is relying on my eyesight ..
Originally posted by yougz View Post
Hi, so the app works fine for Netflix 4K? Does it only works on KM6? And are there other Netflix 4K apps for other devices?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi, so the app works fine for Netflix 4K? Does it only works on KM6? And are there other Netflix 4K apps for other devices?Last edited by Funkoyote; 11 February 2021, 16:19.
Yes, this modded app works in 4k. It would NOT work on my Mecool KM1, which is the last Mecool box.
Originally posted by Funkoyote View Post
Netflix mod apk alike for Mecool KM1: https://4pda.ru/forum/index.php?show...991766&st=2200MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by trebor View Post
Because like that this device is unusable on HDR TV. The colors are dull and are not the right ones. It is enough to look at the logos of the big brands (Youtube, Netflix ...) to realize that there is a color problem.
I do not understand because this problem is on several recent boxes.
So that makes it a device to recommend only for people whose TV is not HDR.
Unless you have a tip
Pity ...
Originally posted by yougz View PostAny idea how to disable HDR on this box which does not have a switch to disable HDR?
Pity ...
Originally posted by RiCkLaR_atvX View Post
Check your TV's internal settings, my TV has an HDR setting per HDMI input, have to enable UHD/HDR (my other TV has to activate HDMI-2.0 per input) on the specific input that your Amlogic device is connected and then the TV will force correct SDR-to-HDR to correct the colors that the box is modifying incorrectly. My specific UHD-TV is from 2019 and the TV registers HDR always-On because that is what the device says it is transmitting to the TV but the TV's processor recognizes the incorrect color transmission and corrects it, but older TV's may not be able to fix the problem.
The only setting I have on it that looks like it is HDMI 2.0 but even turning it off it doesn't change anything.
The new Chromecast has the automatic HDR switch.
I tried the Mecool KM1 and indeed on my tv the Mecool KM1 has a nice image unlike the KM6.
I don't understand why they let this go, especially since it is a problem that is known now. Many users complained that the Tivo Stream 4K could not work properly on their TV ..........
Is there another link for the APK? This one no longer seems to work ...
There are currently 1528 users online. 0 members and 1528 guests.
