TechDoctorUK has YouTube tutorials on disabling the stock launcher of AndroidTV devices with some custom apps so you don't have to actually type ADB-commands, just install the apps and click a few things and the new launcher will take over. You will need the "Nvidia Launcher Manager" to disable the stock launcher.apk, the LauncherX.apk to select your new launcher, and the ???.apk of whatever you choose Nova, Lawnchair2, Evie, etc.
MECOOL Android TV Box KM6 Deluxe Edition Powered by Amlogic S905X4 AVI supported
Originally posted by RiCkLaR_atvX View Post
Should be same ADB commands to disable the stock launcher as Nvidia ShieldTV, of course don't disable original.apk until after you have installed another launcher to be your primary.
Originally posted by Hideiyoshi View PostAin't working appreciate if u could share pls. Thanks mate
I notice that remote not work very well at all, as it has to be pointed to the box, whereas I thought a Bluetooth remote would work regardless which direction you point, as long as you are within reach. I used at a distance of not more tan 2 meters.
Anyone who owns a KM6 can confirm my experience, or am I dealing with a faulty box/remote?
Originally posted by Jancales View PostI notice that remote not work very well at all, as it has to be pointed to the box, whereas I thought a Bluetooth remote would work regardless which direction you point, as long as you are within reach. I used at a distance of not more tan 2 meters.
Originally posted by X92-2GB View Post
the original batteries are bad, buy new good ones, like Energizer Lithium, or Duracell Max. The remote for KM6 has IR for turn on and off. Something about the box keeping it's IR on all the time. Bluetooth is turned off while wifi stays on. Seems like the firmware has a problem with mis aligning what radios are to be enabled during shut down or deep sleep.
When in sleep mode I can switch on box, but when powered off, unable to switch box on with remote, even holding the remote 20 cm from the front of the box.
During operation of the box have always have to point the remote in the direction of the box.
I tried now standing right in front of the box, and pointing to the left or right wall, the box doesn't respond.
When pointing to the ceiling box responds, so I have either a faulty remote, or a bluetooth of the box isn't working properly.
Gonna order a new box, and send them this one back. Hope not all of them will be like this, because then I can get better boxes for less money
Originally posted by Jancales View PostWhen powering off the KM6, long press power button and select power off, I can't power up with the remote.
Anyone can confirm this is normal behaviour, or something wrong with my box?
Edit: I am running an updated firmware that Mecool emailed me 2 or 3 weeks ago.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Just tested my KM6 Deluxe and don't have this issue. When I power OFF the device, the light in front turns "orange". I do have to get close to turn it back on, since I have physical obstructions in front of the box.
The bluetooth issue seems to be fixed in the meantime. I did unpair the remote and pair again, and now it works from in the next room. Still can't power up, but I can get it out of "sleep".
Could you please forward the firmware to me?
Do you power off by long press the power button and select power off, and not just put it to sleep by short press power button?
Could you please forward the firmware to me?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
What was the reason you received the updated firmware from Mecool, what issues did you have?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2991 users online. 0 members and 2991 guests.
