MXQ_RK3229_EMCP_V.4.0 Badly need help :(
Good day guys! Is there someone by any chance know this kind of box i recently mess. My MxQ TV box suddenly shutdown and stuck on the bootanimation, So I'd try to flash a firmware i got on youtube and flash to the box, it was then a successful flashing but unfortunately it not boot up endingin brick tvbox, it doesn't even detected now in my computer, may i just ask for assistance if do you know this kind of chipset and is there a possible way to bring it back to life. for references i woulf be attaching photos. thank you in advance. and keep safe always.Tags: None
Short Ground and Clock Pin to bring it in the Maskrom mode and ask the seller for the correct firmware. Or you can prepare an SD card through SDDiskTool_v1.62 with the correct firmware on it and then run the RKDevTool_Release_2.79 with the SD card inserted in the board. Do not flash any random firmware. RKDevTool_Release_2.79 will show "found one loader device". Then you can flash the firmware. You can download these both applications from Rockchip Github. Flash only rk3229 firmware. There are also rk3228 firmware but they will brick your device and you will get unrecoverable "prepare IDB Fail error".
Originally posted by dtkoywaf View PostShort Ground and Clock Pin to bring it in the Maskrom mode and ask the seller for the correct firmware. Or you can prepare an SD card through SDDiskTool_v1.62 with the correct firmware on it and then run the RKDevTool_Release_2.79 with the SD card inserted in the board. Do not flash any random firmware. RKDevTool_Release_2.79 will show "found one loader device". Then you can flash the firmware. You can download these both applications from Rockchip Github. Flash only rk3229 firmware. There are also rk3228 firmware but they will brick your device and you will get unrecoverable "prepare IDB Fail error".
First image
To the right of CPU 3228A is Micron eMMc JWA60/5LA98 / contact points ....
To the right of CPU and lower/centered between USB Ports looks like
GND
RX
TX
Vcc
For serial/U-art communication maybe
Second image
ESP 8089= wifi Soc
An image of Backside may help
You will need original Factory Firmware for best chance at recovery
Pay attention to EMCP listed in your title
Sorce that Firmware
Happy Testing
GND
RX
TX
Vcc
Second image
ESP 8089= wifi Soc
Sorce that Firmware
Happy Testing
Originally posted by dtkoywaf View PostI do not see any Clock and Ground connections in the pictures you posted, maybe you should take pictures of the back of the board so that I could have some idea.
here bro, thanks for your time
short it with a wire to the adjoining USB port on the board, do not connect the power source to the board while shorting any pins on the board. try this pin. short this pin while connecting the USB cable. The safest way is to create a bootable SD card or USB flash drive. https://ibb.co/tZnrj71
Originally posted by dtkoywaf View Postshort it with a wire to the adjoining USB port on the board, do not connect the power source to the board while shorting any pins on the board. try this pin. short this pin while connecting the USB cable. The safest way is to create a bootable SD card or USB flash drive. https://ibb.co/tZnrj71
UPDATE! dtkoywaf thanks for your help man, I successfully flash a custom firmware, unfortunately the wifi is not working, but it is ok rather than a device not working. https://ibb.co/4gfBHMP I don't have a soldering iron. Lol.
Originally posted by charlieoring View PostUPDATE! dtkoywaf thanks for your help man, I successfully flash a custom firmware, unfortunately the wifi is not working, but it is ok rather than a device not working. https://ibb.co/4gfBHMP I don't have a soldering iron. Lol.
can you write this method by step by step
thank so much
my box brick led blue only
thank so much! please help
There are currently 3339 users online. 0 members and 3339 guests.
