MXQ_RK3229_EMCP_V.4.0 Badly need help :(
Hello! Does anyone have, maybe the firmware 5.1 from Superceleron was lying around in the archive, otherwise the link from https://forum.freaktab.com/ is not working!
Thank you
Originally posted by slavco78 View PostHello! Does anyone have, maybe the firmware 5.1 from Superceleron was lying around in the archive, otherwise the link from https://forum.freaktab.com/ is not working!
Thank you
charlieoring can i have your fw link that you flashed. my box bricked too but i dont have fw. thx
Originally posted by hoangtnt View Postcharlieoring can i have your fw link that you flashed. my box bricked too but i dont have fw. thx
send box for me to slove it
Originally posted by charlieoring View PostUPDATE! dtkoywaf thanks for your help man, I successfully flash a custom firmware, unfortunately the wifi is not working, but it is ok rather than a device not working. https://ibb.co/4gfBHMP I don't have a soldering iron. Lol.
Originally posted by Shinra28 View Post
How did you do this charlieoring ? what pin did you short and where??
hmm let me search for it i think i have around here somewhere...
extra info: Once the installation is finished, it should change to loader, right? still in maskrom.
Hello,
You can try any rom you like with the correct Wi-Fi chip, but make sure you keep you existing loader or flash a compatible one. If you don’t, your device will not start. Regarding loaders: if you can unpack roms, collect its loaders. I collected a lot of them and only one of them works for my machine.
Another thing you should note: Always open and check parameter file with the memory addresses that the program uses to flash. In every file there are two memory addresses, the second one must match with parameter file. And its name of course. Then you flash.
When I realized this I could flash any rom with my loader and got 80% chance to boot successfully!
If you are lucky, you can start it again if it crashes with multitool SD card and erase the flash so you can reflash it.
Note that I have a different device, MXQ Pro 4K 5G that is version 3.0 with sv6051 Wi-Fi chip.
Note that by erasing the flash memory will remove the loader as well and the device will go straight to mask rom mode.
If you are not lucky, you’ll brick it and will require a short to emmc pins to recover it. Search for it before you begin. There are photos of this procedure. I have done this a thousand times for my box and finally it worked.
The best edition I found that makes my device working without burnup temperatures, is with android 7.1.2. I found android 8 and 9 if I remember correctly but the device gets too hot and it’s slower too.
The only problem is that the roms are manipulated and the sizes of ram and Emmc differs. They are displayed intendedly false to make customers buy the products…
I hope this is helpful.
There are currently 3575 users online. 0 members and 3575 guests.
