MK808/B Overclocked Kernels Released
Originally posted by mike77 View Post
Test at your own risk indeed... I wonder how many people could run the extreme stable.
Here is a changelog:
Also small review of new fixes in 1.5:
1. Fixed governors they now working exectly as they must work.
Only some changes in 2 governors (userspace and powersave they allways set to minimal freq) as example if You will set 512-1416 they allways will be at 512Mhz, while performance governor allways will be set to max freq,
other governors working as expected (there was stopper @1416Mhz so they was never working on higher freq's)
Actually I'll put the stopper back for users who don't understand it's not safe without additional cooling (they said "I read in tech specs" and "antutu showed on stock FW 1608Mhz" it's not correct ! Antutu shows max freq, but there is software stopper it won't get freq higher of limit, in stock FW actually it's 1008 or 1200Mhz, but it will say 1608Mhz Max).
Only in extreme Kernel I'll disable all stoppers on all governors, on other versions of kernel stopper will work on all governors @1416Mhz (only performance governor will give real speed 1608Mhz)
2. GPU Driver now don't have UI flicker issue (reported by users of 1.4), so all is smooth on any settings.
(actually I wrote many times they need to disable HW overlay in settings, but they don't understand the english I think and posted videos and review with this issue)
3. GPU Driver tested as stable @533 Mhz (only for extreme kernel) on other versions GPU will be @433Mhz
4. NAND driver working without issues ~10Mb write speed without errors.
5. RAM voltages now changed with CPU freq so now RAM stable @1266Mhz (need more testing and will be only in extreme kernel) other kernels RAM will be fixed @533Mhz
6. 1366x768 resolution will be automatically added to resolutions list if supported
(works with many HDMI-DVI converters).
All credit goes to 2dark4u.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Ynt: MK808/B Overclocked Kernels Released
Originally posted by ididmytime View PostThanks, was waiting for someone to leak the test builds.
GT-N7000...
Originally posted by phinc View Post2dark4u, kizs or omegamoon kernel are the only choice. But they are only for Android 4.1 and you will loose Wi-Fi and Bluetooth because they are for MK808 not MK808B.
Sent from my GT-I9100 using Tapatalk
GT-N7000...
MK808 - Ubuntu 12.10 home://io (Olegk0 3.0.8 Kernel)
There are currently 1437 users online. 1 members and 1436 guests.
