X96 X6 Android 11 RK3566 Quad Core 4GB RAM 32GB ROM Dual WIFI Gigabit LAN 4K HDR
What do you mean? All I did is download the source code I linked , inside it there are apk files ... I copied them to usb drive , opened the drive through xplore app , long click the apk file , selected , install apk , and then opened the new apps from apps ... or just selected the new launcher when pressed the home button
you are not supposed to double click the apk ..... you do a loooong click , a menu with options appear , you select install ...
hk1 firmware (the one I am using ) fixed a lot of issues I had with the stock firmware
for example , Hyperion grabber crashed when opened on stock firmware , but loads fine and works great with the latest firmware. ( and my tv ambilight changes based on the box screen )
1440p on YouTube had green spots all over ... now it’s fine
Most 4K on YouTube failed to load ... now it’s fine ...
just contact the seller you got your box from ... they usually send you the latest firmware right away ... you have to ask them every month for updates ... they never contact you or give you the source from where they are getting these ... dumb
Hi Trigu
for WF 5GHz ;is this stock-rom or whay F/W?
because of I never seen on the menu 5GHz,as I saw only 2.4
now I'll re-d/l above D.Assist.+Fac.Tool and .img file
than start again
Th4 really cant understand the device 5Ghz support!
as I never been happened this kind of 5GHz issue before
I'v used many Boxes incl. 2 of TVs even SAt.Receiver etc. all are fine connected with 5GHz
Thanks for all
failed again!
@minya's gave it above
>installed D.Asist(than reboot) its OK
>opened F.Tool its OK
-load f/w and its OK
now select "Upgrade" or "Restore" (I'v tried both but failed)
-clicked RUN
>connect USB cable and its OK(have seen on the Tool) Green LED is ON
>hold reset button(buthing happen!!)
after 3/5 seconds; I got en error warn>>"Download Boat Fail"
Device Type;MASKROM
I'll try again with USB-cable and Power cable both at same time
As I remember that when I use some of old RK3399 boxes;I did it without any problem to flashing!
but this time mind blown
as per your definition that I missed to connect power cable only
this box get me sick
and so crapy then RK3399!
at least RK3399 with "GPU Mali860" way better picture quality!
you know it dear gefattern with your RK3399(X99)
Try to connect the console to the computer with the reset button pressed at the beginning, as soon as the port is determined in the program, release the reset and press run. If you have a system unit and not a laptop, use the usb connector in the back and not on the muzzle. Use Factory Tool 1.72.2
Originally posted by bergamesk View PostI'll try again with USB-cable and Power cable both at same time
FIRST , the Way to flash is on every RK Box the same , is it fixed now ,
Box up running again ???
greetings / gefattern
HDR works ...
from my test , only webm worked and only using the device “media player”
as you can see ... before playing the video .... tv shows no HDR
i tested a few 4k60p downloaded from YouTube as webm and mp4 ... mp4 don’t load , webm load in HDR and tv shows that is HDR. .... this is the hk1 rbox r2
update : checked also hvec 10bit hdr and also played in hdr
weird mp4 hdr downloaded from YouTube didn’t work but one from a torrent worked
There are currently 2090 users online. 1 members and 2089 guests.
