X96 X6 Android 11 RK3566 Quad Core 4GB RAM 32GB ROM Dual WIFI Gigabit LAN 4K HDR
thanks to balbes150 from armbian for these images
to be able to boot any of these images , you need your device dtb file (device tree blob)., it can be extracted from your device firmware ( from the recovery partition , as this dtb file is not android but Linux )
once you have the dtb , flash the image to an sd card , Mount it in a Linux system , mound the 2nd partition from the flashed image , copy your dtb file to the /boot/dtb/rockchip directory
modify the /boot/extlinux/extlinux.conf file to use your dtb file instead of firefly dtb
insert the se card in your device , turn it on
If you don’t change the dtb you will get stuck during boot process due to missing hardware ( firefly board have more components , which are disabled on our devices dtb file )
1st boot will ask to set a password , and user , then desktop will load
everything works , only wifi/bt is not since they didn’t add our device wifi driver, just a matter of adding it (hk5325f in my case ... )
once done that , to have hardware acceleration , I had to also install the GPU drivers (Mali bitfrost) , the MPP service drivers , and update some components to include the board libraries , librga , Libdrm , v4l , gl/gles
all these drivers , libraries are inside rockchip GitHub , and are updated every few days ...
due the lack of help from other developers here , which are already releasing mods , but just for their station m2/p2 box ,
and they rather answer “ the manufacturer said “ instead of just building one image with my dtb to test ... and my main job .. I had to pause all my researching to try to run a normal updated android ‘ Linux on these devices
proof of concept ... with the right software , these boxes run smooth , cold , I wanted to compile kodi with true hardware decoding and hdr ( since it uses ffmpeg , and I successfully compiled and used rkmpp enabled ffmpeg)
but ... no help from who is already doing it ... , I’ve been asking for like 2 months already from mo123 to just release one image using my dtb .... all out boxes android issues are fixed on his images ...
but no images , no source released , his answer “ manufacturers run one line code to build updated , firmware , ask the manufacturer”
720/1080p AV1 won't work, it's only supported on Amlogic S905X4 devices.
Install Magisk Alpha since Magisk has been abandoned by the developer since he joined Google's security team.
GitHub is where people build software. More than 150 million people use GitHub to discover, fork, and contribute to over 420 million projects.
Use RKDevTool/RKAndroidTool, load your firmware in the last tab and press Unpack.
Copy the unpacked boot.img to your device and select it in the Magisk app.
You will get a patched boot.img in your download folder.
Flash this patched boot.img through Developer Options(Click 7 times on About, Build Info in TvSettings)
Flash Image - Select boot partition then your patched boot.img
If there is no TvSettings then use RKAndroidTool, Load partitions and flash the patched boot.img to the boot partition only(checkbox selected)
Reboot the device.
I have successfully prepared boot.img with Magisk patch but from now on I have a problem with detailed instructions for flash patched boot.img. I don't know exactly how to load boot.img to RKDevTool. Can you guide me in more detail on how to do this.
If I understand correctly, the first variant of how to perform flash is made via flash directly on the TV box (in the TV Box settings), and the second via the PC - TV box connection. If anyone else knows this procedure, I will be very grateful for any help.
Has anyone tried FW from Orbsmart TR43? The specifications are the same and the FW is here: https://www.mediafire.com/file/olrqb...20121.zip/file
it all the same
it is a build from december with the 4.19.172 kernel
and all are as bad and good only firmwares with higher kernel can have better support
all firmwares boots just by flashing it to a rk3566 quartz64-a no editing needed
only the t95 boots then stuck in in a loop in in android
Originally posted by H-Tab View PostHas anyone tried FW from Orbsmart TR43? The specifications are the same and the FW is here: https://www.mediafire.com/file/olrqb...20121.zip/file
the H96_Max is with a rk809 pmic same as the firefly m2 powermanager so the image wont boot on other devices out of the box
the rest all boots on a quartz64-a that was the funny thing
the Orbsmart TR43 X96 and the T95 have the ir led on pwm@fdd70030
the X88pro R2_HK5235F R3_HK5235F have their or led on pwm@fe700030 the x88 support a lot of ir remotes
the rest is little the same of that boards only the used vfd (clock display on front of device ) is diffrent
the h96,x96,tr43 are on rockchip sdk rkr9
the station m2 is on sdk rkr10
and the rest is on sdk rkr 7
the current sdk is RKR11 aka android-11.0-mid-rkr11.2 for android 11
There are currently 2386 users online. 0 members and 2386 guests.
