T95m S905X (P212) 1G+8G ROM/Firmware needed
    Hi all.
    I stuffed up with my box.
    Box: T95m S905X (P212) 1G+8G @ Android 7.1.2 (before)
    I try to flash with Aiden's Android 7 universal ROM and now stuck at the splash screen forever.
    I couldn't find the original ROM to go back.
    Could someone help me provide a link to download the stock ROM with the front screen supported please?
    Many thanks.
    Jerry
    aidanmacgregor ,please help.
      Can someone help please?
      It's urgent.
        Originally posted by jerrymouse1986 View Post
        Hi all.
        Many thanks.
        Jerry
        It is a S905L/P211 device. Which internal memory is soldered onto the PCB?
          It's essencore I3E-8GTH7CMRE eMMC
              Try this FW
                Try this FW
                It doesn't work.
                Before I wiped the box, I saw the cpu model is P212 in recovery. That should be S905X isn't it?Click image for larger version
Name:	Screenshot 2021-07-01 001510.png
                  bumerc , please do help.
                  Thank you very much in advance.
                    jimennis ,This version looks correct. But it keeps connected and disconnected, not getting pass 2%.
Name:	Screenshot 2021-07-01 094134.png
                      Please help, gentlemen.
                      Really need your help.
                      The box is not recognized when plug in.
                      I have to short the pin on the emmc to let the pc recognize this device.
                      The I tried bumerc S905L firmware, failed at 7%.
                      Tried jimennis T95M P212 firmware, failed at 2%.
                      Aidan's universal ATV firmware, failed at 7%.
                      Is there anything I did wrong?
                        1. Download this script.
                        2. Burn aml_upgrade_package to the mSD card with Burn Card Maker.
                        3. Copy the script to the FAT partition of the prepared mSD card.
                        4. Now insert the mSD into the box, short-circuit the MaskROM pins on the eMMC.
                        5. Start the box and release the pins after approx. 2 seconds. The script now resets the eMMC memory to the delivery status.
                        6. Remove mSD from the box and repeat UBT installation
                          bumerc , I follow your instruction but it seems not helping to resolve this issue.
                          Does the mSD partition must be FAT(16) or okay with FAT32 or exFAT?
                          I formatted as FAT32 but doesn't work.
                          On the step 4, with the sd card inserted, computer won't detect the box when I short the pins.
                          I waited for 30 seconds, move on the step 5, eject the sd card, the box is detected.
                          Kick off the UBT flashing, failed at 7% with your firmware and the another one.
Name:	Screenshot 2021-07-01 172447.png
                            bumerc
                            I give another try with your S905L firmware.
                            I waited for 30 seconds, move on the step 5, eject the sd card, the box is NOT detected as well........
                            What should I do then?
                            If the box cannot be detected, I cannot do UBT process.
