Success , Armbian from station m2 on rk3566 android boxes !11
It appears you need to do some debugging steps on console (uart) as it’s not booting the sdcard as it should
‘all I did to boot armbian , was to download an image , mount the image under Linux , changed the dtb file using my device extracted dtb file , then flashed it to sdcard using balenaetcher
Inserted sdcard , plugged in my device
uboot then sees the sdcard , and in my case recognize it as extboot Linux , and boots
if yours doesn’t , you must solder wires to the uart pins , and connect to console and manually type the commands to boot from it...
i don’t recommend flashing armbian to emmc , it’s not including hardware acceleration ( I had to compile drivers to enable them from rockchip source GitHub )
Originally posted by Trigu75 View PostIt appears you need to do some debugging steps on console (uart) as it’s not booting the sdcard as it should
Hi Trigu75!
I can't make my hk1 rbox r2 to work with armbian(I have the 8gb version). I'v tested bullseye with the 4.19, 5.16 and 5.17 kernel with sd card and usb drive but neither wants to boot, it's only booting to android.
I used your dtb file, because i don't know how to get it from android. The imagerepackerRK doesn't work with this image:
Can you help me with it?
Your only solution is to solder wires to the uart holes , and use a usb2serial , on connect to console and watch the booting log , or even stop the boot process and make it boot the sdcard
That is the only way to debug why you are not booting the sd card , usb drive won’t work , unless you set uboot to boot from usb
in my device the boot order is SDcard , Emmc , USB , Network
Thanks, I will try debugging with uart if nothing else works. How can I change the uboot boot order? My device has the older Android version (20210630) and maybe booting from SD card is not allowed in this version. Is there any chance to solve this problem with flashing the newer version? (The software updater app doesn't work)
Here is the uart debug: https://pastebin.com/gW42Pjbj
Actually I managed to boot to armbian by ereasing the emmc, not the most beautiful solution. Now I just have to play with u-boot...
Did somebody managed to turn off the leds?Last edited by ASDosjani; 26 February 2022, 00:00.
you dont have to compile the hw accelration for debian or ubuntu , they are updated to debian 11 and ubuntu 20.4
for mainline there is not yet good hw accc , for no mediacenter it is very good
and booting from sd without a working dtb is no use it would just hang
or even try booting mainline with a extracted dtb wont work
best try is a legacy 4.19 armbian/balbes150 or any other distro (slackware has also muliple board suport and legacy kernel) .
and for both legacy and mainline no mediacenter experience only in android
Did anyone manage to boot from the 5.16/5.17 kernel?
The legacy version is workinig, but java always crashing on it. I'm not sure it's because of the old kernel, but I'm assuming. It's working perfectly fine on raspberry pi 4 and it has 5.10 kernel.
I'm trying to run a minecraft server on it, different jdk versions were tried but it's always crashing. So any idea?
I'm stuck with the booting, here is the serial debug: https://pastebin.com/Zd3KBQuH
I'm also interested why armbian only see 4GB of ram, my tv box has 8.Last edited by ASDosjani; 27 February 2022, 17:11.
Originally posted by ASDosjani View PostDid anyone manage to boot from the 5.16/5.17 kernel?
well that is easy it is your own mess
Firefly RK3566 Board
Rockchip RK3566 BOX DEMO V10 ANDROID Board
Linux version 5.16.9-media
meaning
a uboot from firefly
a dts wich proberly is not from your board
and sure a kernel wich is not from armbian or any other distro with rk3566 support
meaning
And why is armbian and android only seeing 4GB of ram if it has 8GB? Android was seen 8GB at the very beginning but after I reinstalled it, it only see 4.
There are currently 2731 users online. 1 members and 2730 guests.
