The right way is to decompile the dtb to dts , understand how it is configured , find the right pin configurations in it , and edit and compile back from dts to dtc
Success , Armbian from station m2 on rk3566 android boxes !11
i don't even have that box
but your again asking things wich have no use !
and your both just lazy , there is 1 dts file with box in the name and your too lazy to adjust that a little .
disable some usb ports add the lcd , disable some more , check io-domain . and your done
and proberly you can leave the dummy-amlogic out of the dts.
all questions with even try to make a own dts is just useless
Sorry for the misunderstanding, I wanted to ask Trigu75 about the firmware.
Where can I find that dts what you are talking about and how to can I adjust it? With a simple nano? I saw these setting in the kernel settings while building armbian, but I don't know what io-domain means. Now I'm using termux and I can run server from there, but it's not optimal. Sorry for the stupid questions.
realy !!
What model name is in the dtb you got ?!
you dont see that in kernel setting !
just type " decompile dtb " in google
decompile the dtb
read the model name from dts file it creates
build with armbian a legacy build of a rk3566/68 board doesnt matter wich one just with a 4.19 kernel
copy the dtb file wih the name you found in your decompiled dts to another place
decompile the dtb wich you copied from armbian and compare it with the dts you compiled from the dtb of your box
and instead of saying i dont know what io-domains means GOOGLE it " io-domain rockchip"
your dtb says
io-domains {
compatible = "rockchip,rk3568-pmu-io-voltage-domain";
status = "okay";
pmuio1-supply = <0x29>;
pmuio2-supply = <0x29>;
vccio1-supply = <0x29>;
vccio3-supply = <0x29>;
vccio4-supply = <0x2a>;
vccio5-supply = <0x29>;
vccio6-supply = <0x2a>;
vccio7-supply = <0x29>;
phandle = <0x124>;
the armbiam dtb gonna say
io-domains {
status = "okay";
vccio4-supply = <0x29>;
vccio6-supply = <0x29>;
phandle = <0x135>;
and the original dts of the armbian dtb says
/* Need to be modified according to the actual hardware */
&pmu_io_domains {
status = "okay";
pmuio2-supply = <&vcc_3v3>;
vccio1-supply = <&vcc_3v3>;
vccio3-supply = <&vcc_3v3>;
vccio4-supply = <&vcc_3v3>;
vccio5-supply = <&vcc_3v3>;
vccio6-supply = <&vcc_3v3>;
vccio7-supply = <&vcc_3v3>;
and proberly it should be
&pmu_io_domains {
status = "okay";
vccio4-supply = <&vcc_1v8>;
vccio6-supply = <&vcc_1v8>;
and so you go on till you get it working or destroy your board.
Originally posted by ASDosjani View PostThanks for the detailed answer, i will try, but my problem is not that I can't boot into armbian, but java always crashing. What do you mean by "original dts of the armbian dtb"? I found the rk3566-box-demo-v10.dtb and decompiled it and it's only shows the hex values not the vcc_3v3.
and armbian is dead
here a firefly ubuntu
i dont have the device
drr1056 with your dtb
https://drive.google.com/file/d/1k0S...ew?usp=sharing
ddr1560 with your dtb
https://drive.google.com/file/d/1Wbw...ew?usp=sharing
and stop complaining about your bad mc
Originally posted by ASDosjani View PostWow, thanks for your work, but both image stuck at the "Rockchip KERNEL" image. Tomorrow I will check serial debug if needed.
here another attempt i think it boots
your dtb doesnt work with a .219 so i took a raxda .193 and now it even boots on my device with your dtb
yah it is not linux but know i know what was wrong
only have to figure out to make avb image works to get the google things working
it is just 1500000 like normal rockchip
strange should just boot or give a log
you can try reflash it , no uboot ouptput can also means the sd isnt flashed right and otherwise it should boot from emmc
the boot order is spi sd emmc from bootrom
you dont have the power connected
and the uboot boot between device is not been a problem that i know to get at least some output on a serial console
There are currently 2844 users online. 0 members and 2844 guests.
