Success , Armbian from station m2 on rk3566 android boxes !11
So , I downloaded the updated images , since I used the 1st released images when I started the post
i guess balbes150 changed to way these images load , the previous images booted straight , the new images , will boot ONLY if you manually modify the uboot environment and set it to boot from emmc1 instead of emmc0
I’ve successfully booted 4.19.219
Hardware accelerated drivers are not installed , so like in previous releases , sources , and even deb files can be compiled , downloaded from firefly ‘ rk. GitHub , the same if you need ffmpeg , mpv , or anything with included rk acceleration support
Originally posted by ASDosjani View Post
I copied Tigur75's dtb to boot/dtb/rockchip and changed the extlinux.conf to load that one. I'm new in linux so it's almost certain that I will ruin something. I managed to start mc server with legacy kernel, but it's randomly crashes while loading. I tried changing the cpu voltages and frequencyes because I think it is a stability problem, but nothing changed. I can run the server on Android with termux but that's hurting the performance. What should I do now?
And why is armbian and android only seeing 4GB of ram if it has 8GB? Android was seen 8GB at the very beginning but after I reinstalled it, it only see 4.
"I tried changing the cpu voltages and frequencyes " your sure with a dtb your special !
just build armbiam from scratch
and do it just with dts then the nonsens of dtb copy paste etc of trigu75
and change BOOT_FDT_FILE="rockchip/rk3566-firefly-roc-pc.dtb" in BOOT_FDT_FILE="rk3566-x96_x6.dtb" in
build//config/boards/station-m2.conf
and build a image
Originally posted by shaggy013 View Post
Realy you know google find all those answers !!!!
https://github.com/warpme/minimyth2/...r-x96-x6.patch
and build a image
Does that matter where I get the file from? I mean, does the kernel influence the dtb or is it just a file which usable on any kernel and system?Last edited by ASDosjani; 01 March 2022, 11:10.
I am with shaggy013
it appears , asdosjani , based on your answers , that you have no idea what a dts , dtb file is , or what is used in compilations ( based on your Patch file sentence )
If you don’t know / understand how to work on uboot prompt , don’t touch your device
The same for dts ‘ dtb files
you said you are new to Linux ... then you still have a very very very long way to go before you “play” with embedded Linux ( which is what is used , since the whole system is compiled , built for a specific piece of hardware , SOC )
Originally posted by Trigu75 View PostThis is a buggy firmware , the last one which fixes the one you posted (0630) is (0705) was released a week later
this is the one I am using on hk1 r2
RK3566_DC_R2_HK5235F_11_20210705.1409_ota.zip
RK3566_DC_R2_HK5235F_11_20210705.1409.img.7z
https://mega.nz/file/QAMgwDiS#S0G_wc...u645QULLN_9bfE
I have the 4G version , very stable .... , is rooted , you missed my point anyway ... by doing a diff between my dtb and yours can show you exactly where is the memory set , and power that enables your missing 4G
as for other OS .. I successfully booted : armbian , early firefly Ubuntu , early station os , and station android 11 ( with just a dtb change )
you wonder why “early” ... well they recently added some type of hardware checking , although the os loads fine , GUI gets blocked and shows a message saying not a firefly device , and firefly url , then it shuts down
The problem is that I can boot to armbian with both of the dtb, the 4 and 8GB, but if I check it for example with htop it's only shows 4GB no matter what I do.
However in Android it's working fine with the 8GB dtb.
Edit: This it the only difference between the two dtb.
There are currently 2686 users online. 1 members and 2685 guests.
